Camshaft recommendation
- mtbspeedfreak
02 Feb 2015 08:41
Any suggestions for a set of performance cams? Something to match the stock head, 903 cc'c, 29mm smoothbores, and a Kerker with the race baffle.
2000 ZRX 1100
1976 KZ 900- Daily Driver
- mtbspeedfreak
Re: Camshaft recommendation
02 Feb 2015 09:33 - 03 Feb 2015 07:56
Web #118? Andrews 2X?
Orient Express
? Mega Cycle?
I need to keep the tach gear and OVERbucket shims
2000 ZRX 1100
Last edit: 03 Feb 2015 07:56 by mtbspeedfreak. Reason: overbucket shims... duh...
- StreetfighterKz
Re: Re:Camshaft recommendation
02 Feb 2015 09:54
I'd go with either a #118 or #119 Web grind. Not sure about the others. I think anything under .425" lift is safe with SOB.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- DFIGPZ
02 Feb 2015 14:52
better off spending money on cylinder head more bang for the buck plus the fact that valve springs are more than likely weak
1984 750 Turbo
The following user(s) said Thank You: PLUMMEN
02 Feb 2015 16:41
Andrews doesn't make these cams anymore. I have 1X, the 2X are better. Considered "drop in" cams. I'd go with something like that. New springs are a good investment and new seals are a must. How many mile in the bike?
02 Feb 2015 19:18
+1 on Doug and Steve's cam recommendations.
A point of clarification- with shims UNDER bucket, the sky is the limit. With shims ON TOP of the bucket, .410 is probably the limit. Certainly anything above .425 is asking for trouble.
02 Feb 2015 20:01
High lift cams are suitable for heavily modified engines. For a "mild" build they offer little to no benefit. The head has to be ground to accept the larger lobes as well as the valve cover. The shim under cam followers are a good start (though harder to adjust) and the springs have to be matched to the size of the cams and bore. A radical overbore will make the engine temperamental and prone to overheating. Not suitable for every day riding. Best to stay close to stock. Not to mention wearing out tires. I've gone through 4 new tires in less than two years.
02 Feb 2015 21:17
If you've got the ponies, you might as well ride them.
- mtbspeedfreak
03 Feb 2015 07:56 - 03 Feb 2015 07:58
Nearly 50k on the bike. I have either a Yoshimura Series II system or a Kerker with the comp or race baffle to put on, as well as "ported and polished" smoothbores. I've got the Kerker and a street baffle and the stock 26s on there now.
I'm just looking to help it breathe a little better; a mild gain without making any permanent modifications without the need for shim under bucket. I have a gnarly 1105 mill to put in once rebuilt, but that'll be several months, likely a year down the road.
2000 ZRX 1100
Last edit: 03 Feb 2015 07:58 by mtbspeedfreak.
03 Feb 2015 08:32
See if you can find some drop in cams.
