Exhaust valves
  • ThatGPzGuy
  • ThatGPzGuy's Avatar Topic Author
Exhaust valves
01 Feb 2015 14:25 - 01 Feb 2015 14:26
#660324
Hey Guys,
The GPZ has been down due to the starter clutch. I am working on that now as well as a few other small issues.
I was taking a look down the exhaust port and I noticed a couple of things. One, plenty of deposits around the valve stem. And two, the #4 valve looks a little different.
Here is what 1-3 exhaist valves look like:
[IMG
Here is #4:
[IMG
I know the pics are not the best but the #4 valve looks cleaner and a little bit oily. Valve stem maybe? Problem?
The engine is out right now and I was not planning on doing anything other than the starter clutch.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
Last edit: 01 Feb 2015 14:26 by ThatGPzGuy. Reason: sp
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Exhaust valves
01 Feb 2015 16:13
#660332
Valve seals. Get Viton ones, lap the valves and ride the piss out of it.
  • DFIGPZ
  • DFIGPZ's Avatar
Re: Exhaust valves
02 Feb 2015 14:54
#660404
looks like valve seals dried up hit me up if you need vitons see my signature.
1984 750 Turbo
  • !Seymore
  • !Seymore's Avatar
  • Ride on...
Re: Exhaust valves
03 Feb 2015 00:21
#660462
Not to HJ, but... DFIGPZ, are they the seals with the spring at the top, or the band below? Can we get a PIC?
TIA...
C.
79' KZ650-D2 [fsm] (Max)
83' KZ750-F1 LTD [clymers] (Kay)
82' KZ1100-D1 Specter (another project)
78' KZ650-B2a (J&H, A Project)
91' KZ1000-P (P = parts)
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Exhaust valves
03 Feb 2015 06:42
#660472
This is what I bought this time around. Springs $68.96 valves $130 Viton seals $25.49.
The spring had never been changed, I could see the intake valves were worn through the spark plug hole, I was fouling plugs and the head showed signs of over heating. I was hoping to gain some adjustment range. I did on the intake and the seat pattern was a little wide but not too much. The exhaust I lost some. The valves were seating on the carbon left by the oil. Lapped in well so I put it together and am riding the piss out of it. The valve train sings like it when new.
  • Nessism
  • Nessism's Avatar
Re: Exhaust valves
03 Feb 2015 07:39
#660479
Deposits in the exhaust track are perfectly normal If the bike has a header and someone rejetted the carbs on the rich side the carbon will build up faster than desired though. Unless the bike was burning a bunch of oil I wouldn't pull the head. If you did so for other reasons, new valve stem seals should be on the menu of course.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Exhaust valves
03 Feb 2015 07:57
#660482
I'd have to agree. if the plugs arn't fouling, no need to tear into the head right now.
steve
  • ThatGPzGuy
Re: Exhaust valves
03 Feb 2015 08:50
#660487
swest wrote: I'd have to agree. if the plugs arn't fouling, no need to tear into the head right now.
steve
The plugs don't foul but it does use some oil (leaks some too).
Does the head have to come off to replace the valve stem seals?
Thanks Everyone
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Exhaust valves
03 Feb 2015 08:56
#660489
Yes, be ready to do more while in there.
  • ThatGPzGuy
Re: Exhaust valves
03 Feb 2015 10:02
#660493
swest wrote: Yes, be ready to do more while in there.
Story of my Life :P
Thanks Steve
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
