Oil light coming on and staying on just after star
  • noroaches
  • noroaches's Avatar Topic Author
11 Jan 2015 03:40
#658374
I just changed the oil in my kz1000 and the oil light is coming on shortly after it starts.
It flickers but more on than off. what happened, I took the oil filter out and cleaned it with gas checked all the "O" rings and put a little oil on the rim and put it back together.
1988 KZ1000 P
Re: Oil light coming on and staying on just after star
11 Jan 2015 04:28
#658377
noroaches wrote: I just changed the oil in my kz1000 and the oil light is coming on shortly after it starts.
Hello, noroaches, and WELCOME to KZr!
Perhaps the gasoline soaked filter is partly responsible. :unsure:
However, there's a filter by-pass system that's supposed to allow oil circulation around a clogged filter.
Imo, it's best to fit a brand new filter, rather than attempt to clean a used filter.
Couple of other possibilities regarding the oil pressure warning light:
Defective sending unit;
Faulty wiring or loose connection;
Clogged oil pump screen;
Poor oil pump performance resulting from other than clogged screen.
Could fit an oil pressure gauge to determine actual performance.
The oil sending unit is relatively easy to remove and replace.
Good Fortune! :)
11 Jan 2015 04:32
#658378
If a new "oil pressure switch" (aka oil sending unit) is needed:
www.z1enterprises.com/ItemDetails.aspx?i...1100&item=27010-1013
Good Fortune! :)
  • Puffin
  • Puffin's Avatar
11 Jan 2015 04:41
#658379
If the oil light/switch was not a problem before the oil change then it should not be a problem now. More than likely the oil filter ;) I have to ask why would you even try cleaning a paper filter in gas :(
KZ1000 J Long Term Owner
KZ1100
KZ1100 Spectre project
  • noroaches
11 Jan 2015 04:42
#658380
ok I will get a new filter. where is this screen that maybe plugged, can I clean or replace that
1988 KZ1000 P
  • noroaches
11 Jan 2015 04:44
#658381
there was only a steel filter, no paper filer at all
1988 KZ1000 P
11 Jan 2015 05:01
#658384
Oil in the sump passes through a screen into the oil pump.
Access to the screen and pump is by removing the oil pan on the bottom of the engine.
Good Fortune! :)
11 Jan 2015 05:08 - 11 Jan 2015 05:08
#658385
Here's a link to the Z1 FSM (Factory Service Manual) in KZr's FILEBASE:
www.kzrider.com/filebase/search/finish/1...asaki-service-manual
Check out the oil pump diagrams and information.
Good Fortune! :)
Last edit: 11 Jan 2015 05:08 by Patton.
11 Jan 2015 05:16
#658386
noroaches wrote: there was only a steel filter, no paper filer at all
Perhaps there was no filter, and just the bolt (with holes in it) that attaches the filter cover.
Am unfamiliar with any type of steel filter being used instead of the usual stock-type paper filter.
Perhaps seeing the gutted skeletal remains of a paper filter. :ohmy:
Good Fortune! :)
  • TexasKZ
  • TexasKZ's Avatar
11 Jan 2015 06:21
#658397
What weight oil did you use?
The following user(s) said Thank You: !Seymore
11 Jan 2015 07:21
#658404
It would help a lot if you were to add your bike's exact year and model to your signature line. Not all KZ1000 bikes are exactly the same. Ed
  • noroaches
12 Jan 2015 00:58
#658459
10/40
1988 KZ1000 P
