Removing rust scaling on cylinder?
  • taylee
  • taylee's Avatar Topic Author
15 Dec 2014 11:55 - 15 Dec 2014 11:57
#656088
This bike I just pickedup had been sitting for nearly 8 years. Thus, water had found it's way into the cylinder and there is rust scale built up on two of the cylinders. is there a way to remove it without having bore or reline the cylinders?
Here is how the pistons were when I pulled the head. Here I have sprayed them with penetrating oil, letting them soak.
[IMG
[IMG
1985 GPZ750 (non-turbo)
Last edit: 15 Dec 2014 11:57 by taylee.
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Removing rust scaling on cylinder?
15 Dec 2014 12:24
#656090
Is it just surface rust?Maybe try some carb cleaner and a green scuff pad. ;)
  • bountyhunter
  • bountyhunter's Avatar
15 Dec 2014 13:02
#656093
Problem is that as you scrub them, the debris will fall down and get trapped in the rings.
  • taylee
15 Dec 2014 13:10
#656096
I've aleady got the cylinders off the pistons. There was rust and water stuck in the oil rings. So I will replace all the rings to be safe.
  • PLUMMEN
  • PLUMMEN's Avatar
15 Dec 2014 13:12 - 15 Dec 2014 13:14
#656097
Last edit: 15 Dec 2014 13:14 by PLUMMEN.
  • SWest
  • SWest's Avatar
  • 10 22 2014
15 Dec 2014 14:05
#656102
Something few people know. When the cylinders rust, they are stained far into the metal. Back in 87 when I was rebuilding my bike after the wreak, I had a set of Z2 750 barrels. The 903 ones were bored off center by this guy they called "nigger Lee." I don't know why everyone called him that, ( he was Jewish), maybe I do. Any way, I had Clupper racing bore out the 750 barrels to 1015. Lots of meat to take out, they were mad but did a fine job. After all that metal was taken out, I could still see the rust stains. Didn't hurt anything and I still have them stashed away. I bought some KZ 1000 barrels on eBay and that's what I'm using now. (barley fit). The 903 barrels would overheat if bored more than 1015, not much room anyway, but now I can go out a lot more if I want to.
Just saying.
