Stator Cover bolts
- crackerjack
Stator Cover bolts
24 Nov 2014 15:11
So, my stator cover bolts weren't torqued properly and shook loose leaving me with no bolts to secure the stator cover to the engine case, I was wondering if anyone had the bolt specs (bolt diameter, thread type and length) so I can order replacements
- mopguy
Re: Stator Cover bolts
24 Nov 2014 15:42
It would help if you told the members the year and model of your bike.
24 Nov 2014 15:58
Depending on year and model, you may be able to get replacements fem Z1 Enterprise
- crackerjack
24 Nov 2014 16:31
don't I feel silly for forgetting to include even the most basic of information. >.<
It's an '82 gpz750 / gp750z / kz750-r1 whichever you want to refer to it by.
24 Nov 2014 16:48
You can go to your hardware store and get some Allen head # 6 bolts. Measure the thickness of the cover and add 5/8" or so. Cheap fix for the time being.
- zukdave
24 Nov 2014 17:27
swest I think you mean an M-6 not a # 6.
CJ take a screw out of another case and go to Lowe's or home depot
and match up the thread and get Allen head's. long enough.
The Lowe's here seem to have a good stock of metric black and stainless nut's'
bolt's and screw's.
Take the cover with you I take part's in all the time looking for odball hardware.
bolt's and screw's.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- PLUMMEN
24 Nov 2014 18:44
2 6x40s on the bottem,others should be 6x30s
- crackerjack
24 Nov 2014 18:57
Thanks for the help guys, from what I had measured previously I thought they were M-5 but I could only find them long enough at the local fastenal store after finding out they weren't I didn't' want to go back until I knew exactly which size. I just measured the depth on the case and it looks like the top left and bottom right should be 6x40s, top right should be 6x50 and bottom left should be 6x55.
24 Nov 2014 18:58
Diagram below. Ed
Attachment 00003a_2014-11-24.jpg not found
- crackerjack
24 Nov 2014 19:02
Thanks, I was actually looking for a diagram and couldn't find one, it's interesting that the bolt length I measured is different than that listed in the parts diagram.
24 Nov 2014 19:03
Your'e right M 6. Any good hardware store will have them. Expensive though. You can order a full kit on line but for the time being I meant.
- PLUMMEN
24 Nov 2014 19:09
The bolt depot.com
