81 KZ1000 doesn't go past 6000 RPM. Any ideas??
  • whirlwind598
  • whirlwind598's Avatar
Re: Re:Re:81 KZ1000 doesn't go past 6000 RPM. Any ideas??
15 Feb 2015 21:43
#661738
650ed wrote:
whirlwind598 wrote: Kinda sounds like my 750 does the same at 8000 around 90+mph. Dont know since the gauge only goes to 85. But that's probably its limit.
If your KZ750 is a 4 cylinder model (please add you bike's year & model to your signature line) I can personally attest that regardless of that NHTSA dictated speedometer the bike would exceed 120 mph when new. If yours won't go past 90 it needs work. Ed
I wouldn't be surprised if it does, but im no mechanic. I'll run it how it is until I upgrade if I can.
  • HBKwaka
  • HBKwaka's Avatar
Re: 81 KZ1000 doesn't go past 6000 RPM. Any ideas??
16 Feb 2015 06:54
#661755
daveo wrote: I bought a set of KZ Police carburetors for parts, and found that each slide diaphragm had small a hole in the side of the metal cylinder. When checking into what that hole was for, some tech at Vance & Hines thought it was there meant to be a limiter of some sort.
If your slides have the hole, it could be what your problem is...if not entirely, it may be contributing to it. :unsure:
I modified the set of slides by painstakingly filling each with JB Weld, after running a tiny tap through each one to rough-up the hole perimeter for adhesion (see photo).
Those slides are exactly the same as the original ones to my BS34's (with that exception), and are now sitting in a box, waiting to be used again. The rubber diaphragms are in excellent condition, and the hole plugs held up very well, for the season I used them.
Send a PM if you would like more info.
That is correct. Epoxy over each hole and no more rev limitations. Did it on mine.
  • SWest
  • SWest's Avatar
  • 10 22 2014
16 Feb 2015 08:03
#661765
Guess they didn't trust the cops. No wonder they were so slow.
  • SweetwoodSUP
  • SweetwoodSUP's Avatar
03 Mar 2015 00:35
#663272
I would love to see a n update to this thread. I'm betting it's ignition.
'79 LTD 1000
'84 Ninja 900 (Sold, What was I thinking!)
'81 CSR 305 (sold)
'69 BMW R75 (Sold)
