81 KZ1000 doesn't go past 6000 RPM. Any ideas??
- daveo
Re: 81 KZ1000 doesn't go past 6000 RPM. Any ideas??
28 Nov 2014 15:06 - 28 Nov 2014 16:22
I bought a set of KZ Police carburetors for parts, and found that each slide diaphragm had small a hole in the side of the metal cylinder. When checking into what that hole was for, some tech at Vance & Hines thought it was there meant to be a limiter of some sort.
If your slides have the hole, it could be what your problem is...if not entirely, it may be contributing to it.
I modified the set of slides by painstakingly filling each with JB Weld, after running a tiny tap through each one to rough-up the hole perimeter for adhesion (see photo).
Those slides are exactly the same as the original ones to my BS34's (with that exception), and are now sitting in a box, waiting to be used again. The rubber diaphragms are in excellent condition, and the hole plugs held up very well, for the season I used them.
Send a PM if you would like more info.
1982 KZ1100-A2/1170 sleeper 😀
Last edit: 28 Nov 2014 16:22 by daveo. Reason: update info
- !Seymore
- Ride on...
28 Nov 2014 15:23 - 28 Nov 2014 15:24
What size fuel line are you running?
Also, when the tank is on, are there any kinks in the fuel line? ...even smaller-ish ones?
I like to check the simple things first...
C.
79' KZ650-D2 [fsm] (Max)
83' KZ750-F1 LTD [clymers] (Kay)
82' KZ1100-D1 Specter (another project)
78' KZ650-B2a (J&H, A Project)
91' KZ1000-P (P = parts)
Last edit: 28 Nov 2014 15:24 by !Seymore.
- murquiza
30 Nov 2014 16:06
Check your voltage regulator, it might be shot and the battery alone can't give enough juice to keep the coils going at high rpm.
Bikes:
1979 KZ650-D2 SR
2006 Vulcan 2000-A
2006 ZX10R
2008 Versys KLE650
1979 KZ650-D2 SR
2006 Vulcan 2000-A
2006 ZX10R
2008 Versys KLE650
- Subbie79
08 Dec 2014 08:23
Here is another update.
This bike is 81 and carb sliders didn't have that limiter feature yet. There are no holes at its sides, except the ones on the bottom.
I replaced 1/4" fuel line and filter with 3/8" ID, however it didn't make any difference.
As for the voltage regulator, I believe VR is working normally. Battery is charging fine, all lights work OK, voltage sensing line is within 0.5Vof the battery reading.
New 3.0 coils were installed. Still doing the same thing.
Dynajet recommended 165 main jets. I'm gonna go back to stock 122.5 and see if it affects.
If not, then will try different main jets that came with the rejet kit. (155,160 & 165)
Any comments or recommendations?
1981 KZ1000K
08 Dec 2014 20:33
Is it for certain that the ignition coils are correctly wired?
Is the ignition timing owner-adjustable?
Attachment coilsconnectionslargefours.jpg not found
- daveo
09 Dec 2014 04:54
:huh: Any chance the cams may be off by a tooth?
- rocmoe
20 Dec 2014 12:35
Did you every resolve your issue with your bike not exceeding over 6000 rpm?
- GPzEric
20 Dec 2014 19:06
THIS -
THIS -
My wife asked me if I still loved her - I said "Honey, I love you more than new carburetor boots ! "
1982 KZ1100B2 (GPz)
1982 KZ750R1 (GPz)
(2) 1981 KZ550D1 (GPz) 1 mint, 1 under construction
1983 GS1100E
1982 KZ1100B2 (GPz)
1982 KZ750R1 (GPz)
1983 GS1100E
- whirlwind598
Re: Re:81 KZ1000 doesn't go past 6000 RPM. Any ideas??
13 Jan 2015 08:50
Kinda sounds like my 750 does the same at 8000 around 90+mph. Dont know since the gauge only goes to 85. But that's probably its limit.
- Tyrell Corp
13 Jan 2015 10:35
I pushed the sliders up and blocked the air port, and the slides come down very slowly. takes about 40 seconds to fully down position. I think diaphragms are ok.
I put a few drops of engine oil on the slides, it should return sharper than that I'd say. Probably not your problem though as the vacuum lifts the slide but the spring returns it.
Those mechanical ATU advancers can be sticky and won't rev past about 6k, I know you said you are getting full advance at 3500 rpm. Are you sure your timing is right?
13 Jan 2015 11:07
Have you checked your cam timing?
13 Jan 2015 11:20 - 13 Jan 2015 11:20whirlwind598 wrote: Kinda sounds like my 750 does the same at 8000 around 90+mph. Dont know since the gauge only goes to 85. But that's probably its limit.
If your KZ750 is a 4 cylinder model (please add you bike's year & model to your signature line) I can personally attest that regardless of that NHTSA dictated speedometer the bike would exceed 120 mph when new. If yours won't go past 90 it needs work. Ed
Last edit: 13 Jan 2015 11:20 by 650ed.
