What's wrong with my rotor/starter clutch assembly
  • seanbarney41
  • seanbarney41's Avatar Topic Author
  • '79 kz1000 LTD '75 Honda CB750
09 Nov 2014 10:39
#653242
It took a long time to collect all the parts for my basket case. Now it won't go back together and function. As I tighten down the rotor bolt, the clutch gets stiffer and stiffer until it will no longer free wheel, and the rotor is still not tight enough to not spin on the shaft.
Check out my pics and see if you can see a problem or a part mis-match...this is a '78 kz1000, engine number kzt00ae073545...
Here is the cover I have. I this correct for my engine?
[img
DSCN0274 by seanbarney41 , on Flickr
  • seanbarney41
Re: What's wrong with my rotor/starter clutch assembly
09 Nov 2014 10:46 - 09 Nov 2014 10:50
#653243
Here is the the stator and rotor I have. Are these correct? I know there are different stator/rotor combos where the rotor fits around the stator but I don't know what year motors use these. Could the taper on my crank be wrong for this stator?
[img
DSCN0278 by seanbarney41 , on Flickr
[img
DSCN0281 by seanbarney41 , on Flickr
Last edit: 09 Nov 2014 10:50 by seanbarney41.
  • seanbarney41
09 Nov 2014 10:55
#653244
There is evidence that this rotor spun on the crank taper. Could this cause the problem? I am concerned about this ridge that looks worn into the back of the rotor.
[img
DSCN0282 by seanbarney41 , on Flickr
[img
DSCN0287 by seanbarney41 , on Flickr
  • seanbarney41
09 Nov 2014 10:59 - 09 Nov 2014 11:01
#653245
Here is a virtual disassembly...tell me if I have something wrong
[img
DSCN0277 by seanbarney41 , on Flickr
[img
DSCN0283 by seanbarney41 , on Flickr
Last edit: 09 Nov 2014 11:01 by seanbarney41.
  • seanbarney41
09 Nov 2014 11:06
#653247
continueing to disassemble...this damper washer thing, I realize comes in 3 different thicknesses, mine was the thickest. I initially thought this was the problem, so I sanded down the rubber to slightly less than the thinnest offered. It does not contact the case before the clutch gets locked up.
[img
DSCN0284 by seanbarney41 , on Flickr
[img
DSCN0285 by seanbarney41 , on Flickr
  • seanbarney41
09 Nov 2014 11:09
#653248
that's about it. Thanks for the help?
[img
DSCN0286 by seanbarney41 , on Flickr
  • seanbarney41
09 Nov 2014 12:30 - 09 Nov 2014 12:32
#653252
found some discrepancies with the fiche. I have part #5 here
this fiche doesn't have that washer, but has part #23...
is this my problem?
sorry my links don't work. I don't know why. comparing fiches for a2 and b2...I don't even understand why there are so many different options for a '78 kz1000
Last edit: 09 Nov 2014 12:32 by seanbarney41.
  • dkoz
  • dkoz's Avatar
10 Nov 2014 10:42
#653294
hi, I'm having the same problem. Member bozo having starter clutch problems as well. Mine didn't come with all the parts if you read his post you'll see what I said maybe those thrust washers don't belong in all of the units I don't know I haven't had a good response with my questions hoping somebody will chime in soon if I find anything out I'll let you know good luck
1978 LTD B2 smashed
1978 Z1R D1
1978 A2
  • mopguy
  • mopguy's Avatar
10 Nov 2014 12:59 - 10 Nov 2014 13:02
#653300
I looked at my service manual and the cover looks like it is the right one. It also looks like you are missing the idle gear and shaft. Look at page64,65,66,67 on the repair manual. If you don't have a repair manual, I remember downloading a PDF version from somewhere in this site, perhaps someone else can chime in and help you download the manual.
Last edit: 10 Nov 2014 13:02 by mopguy. Reason: added
  • floivanus
  • floivanus's Avatar
10 Nov 2014 13:28
#653302
More likely than not someone got in there before and cranked the snot out of it instead of followin torque specs and procedures and wallered out the taper hole in the rotor; or it spun loose once and wallered it out.
Solution; delete the electric start or buy a good condition rotor/clutch; and make sure to install with both surfaces clean and dry, coated with loctite lockin compound and TORQUED properly then you should be okay
Past; 78 kz1000, 83 kz550
Andrew
  • seanbarney41
10 Nov 2014 13:52
#653305
mopguy wrote: I looked at my service manual and the cover looks like it is the right one. It also looks like you are missing the idle gear and shaft. Look at page64,65,66,67 on the repair manual. If you don't have a repair manual, I remember downloading a PDF version from somewhere in this site, perhaps someone else can chime in and help you download the manual.
yeah, I got manuals...and I have the idler gear and shaft. I just didn't bother to install them for the pics.
  • seanbarney41
10 Nov 2014 13:57
#653306
floivanus wrote: More likely than not someone got in there before and cranked the snot out of it instead of followin torque specs and procedures and wallered out the taper hole in the rotor; or it spun loose once and wallered it out.
Floivanus, this is what I think also. Did you see the pic of the back of my rotor a few posts up? Can you tell me if that ridge is supposed to be there?
