79ltd kz1k fit a 77kz 1k frame
  • spdygon
  • spdygon's Avatar Topic Author
27 Oct 2014 20:02
#651949
So the question is will a 79 kz1000ltd fit my 77kz1000a frame?
Ltd seem to have the J- motor or mk2.
Ifound a already built kz1000ltd motor with 1198 kit cams and 29 smoothbores.
Would like to install in my bike.
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
  • PLUMMEN
  • PLUMMEN's Avatar
Re: 79ltd kz1k fit a 77kz 1k frame
27 Oct 2014 20:35
#651954
73-80 900/1000 all fit the same. :)
  • spdygon
28 Oct 2014 14:38
#652018
Awesome thanks
Will be picking up cycle this week
1974 Z1 900 project
  • spdygon
01 Nov 2014 15:48
#652531
so here it is.....its a 79Kz1000 with a 1198 wisco kit 29mm smoothbore and web cams z4...
Bike came with over $1500 in recipts and a new Kerker Header.
Also has a electronic ignition , rectifier/regulader and some Nology Coils( nerver heard of them.
1974 Z1 900 project
  • spdygon
01 Nov 2014 15:49
#652532
1974 Z1 900 project
  • floivanus
  • floivanus's Avatar
01 Nov 2014 16:41
#652540
:unsure: you're parting that one out? Seems close to being a very good bike. I would have started with that and been right at being done by the looks of it
Past; 78 kz1000, 83 kz550
Andrew
The following user(s) said Thank You: peter1958
  • spdygon
01 Nov 2014 16:52
#652541
No not parting out....I bout the bike for the engine.
Once I finish the bike in my sig....I'll be using the engine from the 79.
And use the 77 engine on the 79.
Bike is pretty complete just need a little TLC
1974 Z1 900 project
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
03 Nov 2014 09:20
#652755
nice score there sir.
  • spdygon
03 Nov 2014 14:23
#652795
For the money it was going to cost me to build my 77engine I got a hole bike for much less.
1974 Z1 900 project
  • 531blackbanshee
  • Vendor
  • Vendor
04 Nov 2014 06:01
#652839
spdygon wrote: For the money it was going to cost me to build my 77engine I got a hole bike for much less.
that is a very good way to look at it :evil: !
  • spdygon
06 Nov 2014 19:51
#653109
....so i was test fitting a set of crash bars on my 79......the one bolt that was not long enough was the front top.
did the bars come with new bolts and nuts that would be longer (then originals) when purchase new?
1974 Z1 900 project
06 Nov 2014 22:44 - 06 Nov 2014 22:46
#653121
It's relatively easy and inexpensive to make a slightly longer custom length replacement.
Can get a length of appropriate diameter plain round steel bar stock from the local hardware store, cut it to desired length, and cut treads on both ends.
The thread size must be same as the original part.
Use a nut on the end that replaces bolt-head on the original part.
If the needed diy thread-cutting tap isn't at hand, could probably get the bar ends threaded at a machine shop for very little cost.
Good Fortune! :)
Last edit: 06 Nov 2014 22:46 by Patton.
