Burning oil after rebuild, BAD!
Re: Burning oil after rebuild, BAD!
15 Oct 2015 06:19
On all four? Yes, pull the head.
- mjg15
15 Oct 2015 20:01
I'm with the oil ring guys. I did this on a Wiseco in my air-cooled single, and it would pump half of the oil out of the bike in 5 min
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
- Maravinchi
21 Oct 2015 09:48 - 21 Oct 2015 09:51
Like I said earlier when I pulled the cylinders off the oil rings appeared to be installed correctly ie. Not overlapped...but idk they could've sprang back upon removal...im gonna tear the head apart and check out those stem seals...I kno 5 minutes isn't enough time for the rings to seat but I've replaced rings on a few other bikes b4 and I've never had one smoke like this....im replacing all gaskets and seals and I'm also having a machine shop re-do the honing and crosshatching to match the rings...seeing as 4 sets of new rings runs about 130 bucks...am I able to re-use these rings considering the bike only ran for abt 5 mins?....the ring end gaps are correct and they are not bent in any way
Ps: also used mineral oil on the first start up I was thinking of another bike when I stated synthetic earlier...has anyone ever used maxima sae 10w30 break in oil?
Thanks
Thanks
"Quatre roues déplacent le corps, deux roues déplacent l'âme."
1983 KZ750 F1 Ltd-Shaft
Last edit: 21 Oct 2015 09:51 by Maravinchi.
21 Oct 2015 12:05
Mineral oil? No wonder it smoked. I use store brand light oil and flush it after 500 miles. Sooner depending how much crap is in there.
steve
steve
- jackleberry
21 Oct 2015 12:22swest wrote: Mineral oil? No wonder it smoked. I use store brand light oil and flush it after 500 miles. Sooner depending how much crap is in there.
steve
"Mineral oil" == "Dino oil" == "Conventional oil". I think he just means it wasn't synthetic.
1997 KZ1000P (P16)
2001 KZ1000P (P20)
2001 KZ1000P (P20)
- Maravinchi
21 Oct 2015 12:49
Right ...it was castrol gtx sae 10w40 4t motorcycle oil
21 Oct 2015 12:54
I'll be interested in seeing the valve guide seals. Mine leaked like a sieve. Didn't smoke a lot, just a puff at start up but fouled plugs every 2-400 miles. :dry: Crumbled when I changed them. :lol: Were they changed? Who did it?
- peter1958
21 Oct 2015 14:58steell wrote:Maravinchi wrote: I didn't replace the o-ring gaskets on the the left and right side of the cylinders just re-used them.
Have you ever heard the phrase "Penny wise and pound foolish"? Penny and Pound being used as in English currency.
Those rubber rings are the seal between the oil pressure and the cylinder. I'd have replaced them.
www.kzzone.com/
