Gasket sealant
  • koloj
  • koloj's Avatar Topic Author
Gasket sealant
31 Jul 2014 07:40
#642137
What would u reccomend for nice tight seal and easy removal if needed in the future removal
  • turboking
  • turboking's Avatar
Re: Gasket sealant
31 Jul 2014 08:25
#642144
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
The following user(s) said Thank You: bluezbike
  • turboking
Re: Gasket sealant
31 Jul 2014 08:29
#642145
1985 GS 1150E
1983 GS 1100E
The following user(s) said Thank You: PLUMMEN, bluezbike
Re: Gasket sealant
31 Jul 2014 09:56
#642156
koloj wrote: What would u reccomend for nice tight seal and easy removal if needed in the future removal
What gaskets are you talking about?
In most cases you should NOT use a gasket sealant. The Kawasaki Service Manual shows which gaskets need sealant and where they need it. Do yourself a huge favor and only use sealant where the manual calls for it. Ed
  • koloj
Re: Gasket sealant
31 Jul 2014 12:28
#642168
Like clutch case and valve cover also bottom of the top end not the headgasket
  • Z1Driver
  • Z1Driver's Avatar
  • love the smell of triple smoke
Re: Gasket sealant
31 Jul 2014 12:47
#642170
I agree with 650Ed. A valve cover typically doesn't require gasket sealer to seal if using a quality valve cover gasket. I bought a valve cover gasket for my Z1 off Ebay One time. It leaked so bad gasket sealer would not have helped. I learned my lesson. Now I buy valve cover gaskets from an on line store who have good quality gaskets.
Blue 1975 Z1B
Red 2009 Concours 14
  • koloj
Re: Gasket sealant
31 Jul 2014 13:35
#642173
I got valdpare one from z1 no eBay for me
Re: Gasket sealant
31 Jul 2014 13:57
#642175
Don't use anything on the valve cover. Put it on dry and you should have no leaks and you'll be able to remove the cover many times without needing a new gasket.
On the clutch cover, take a look in the Kawasaki Service Manual. Below is a picture that shows the only place on the KZ650 clutch cover that you should apply sealant. That is the area where the rear of the cases meet, and the sealant (shown in blue) is to be applied only to the engine side of the gasket, not the clutch cover side. Ed
Re: Gasket sealant
31 Jul 2014 14:01
#642176
Here's my view on using sealant; others may disagree.
If the idea of putting sealant on a gasket is to prevent a leak, please consider the following. Let's say you have two metal surfaces, i.e. a cylinder head and a valve cover, and there's a gasket that goes between the two. The purpose of the gasket is to prevent oil from leaking between the two metal components. So let's say you put the gasket in there dry (no sealant at all) and bolt the cover to the head squeezing the gasket between the two. Now consider if you could see that cover/gasket/head joint from inside the engine. You would see metal (the head), the inner edge of the gasket, and metal (the valve cover). Now you splash plenty of oil inside that area so the joint is soaked in it. Now looking from inside the engine you see oily metal (head), the oily inner edge of the gasket, and oily metal (the valve cover). If the oil is going to seep between the metal and the gasket will the oil care if it seeps between the head and the gasket or the valve cover and the gasket? No; if it is going to leak it can leak on the head side OR the valve cover side of the gasket. So, IF the only way to prevent a leak was to put sealant on the gasket you would need to put it on both sides. Fortunately, the dry gasket will not leak on either side, so no sealant is needed. This assumes no one has gouged the metal mating surfaces when trying to remove a gasket that some previous owner has glued on because they didn't know sealant was not needed. In that case sealant may be needed but only on the gouged area.
This brings up another point; in the Kawasaki service manual there are a FEW areas where sealant is called for. The best example I can give is a spot on the KZ650 clutch cover gasket. The manual calls for about 1 inch of sealant on a spot on the engine side of the clutch cover gasket where the gasket covers a joint between the lower and upper engine castings. This is required because mating surface has a seam at this engine casing joint which the gasket alone may not seal. This may not be obvious to someone doing this job the first time. So my best advice is to always consult the service manual to see if and where sealant is required rather than just gluing the gaskets on and later having to scrape them off. Also, you'll save money by not needing to replace gaskets as often because the ones put on dry can be more easily reused. The CD recording of this speech is available at the door. Ed
  • koolaid_kid
  • koolaid_kid's Avatar
Re: Gasket sealant
31 Jul 2014 14:26
#642178
LOL. I'm with you 100%, Ed. The worst place to put gasket sealer is the valve cover. Makes it a real b!tch to remove the cover, then you have to remove the sealant, including the sealant you just dropped down into the head.
This is true for almost all motorcycles, btw. The gaskets, by and large, are meant to go on dry. If certain areas need a bit of sealant, the Factory Service Manual will point them out explicitly.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
  • koloj
Re: Gasket sealant
31 Jul 2014 14:53
#642180
Cool just asking I spent lot pennies bought pit it together last thing I want have buy another kit just cause I have one drip of oil leaking
  • koloj
Re: Gasket sealant
31 Jul 2014 14:55
#642181
Ive done a lot of car blocks but they have so much more surface area between sealing surfaces
