Clutch cable spring
- jsnabbs
- 1981 kawiKZ440
Clutch cable spring
29 Jul 2014 13:21
Can someone please tell me the part number to the spring in the picture, i dont seem to have one anymore.
I cant imagine that i would lose such a thing, would the clutch have worked without this before?
All so, i have the new clutch cable and i noticed the privious one had another spring runinng up the lentgh of it, i dont think it has anything to do with the problem i have now. But why does it have that and do i need it?
Attachment Screenshot2014-07-29at10.16.05PM.png not found
TIME TO TRADE IN THE PEDALS FOR SOME POWER
The following user(s) said Thank You: nlneilson
Re: Clutch cable spring
29 Jul 2014 14:04
- jsnabbs
- 1981 kawiKZ440
29 Jul 2014 14:29
have now, thanks
Part number is 92081-1058
can anyone share light on my other question
29 Jul 2014 15:17
I'm not sure of the purpose, but my KZ650 clutch cable also has the long spring.
Part number 92081-1058 is no longer an "Active" part (it's now obsolete). However, these folks claim to have 4 new old stock ones. Ed
www.oldkaw.com/92081-1058-kawasaki-clutch-return-spring/
- jsnabbs
- 1981 kawiKZ440
29 Jul 2014 15:33
Is there any way that the clutch would work without it? Has it maybe got something to do with my my old clutch had a sring running along the lentgh?
Im finding it hard to belive that I've lost it,,,,,,, but i guess there has to be a first time
- JR
29 Jul 2014 16:10
My 750 clutch cable also has the long outer spring. I have wondered about its purpose and the only thing I could come up with was to prevent contact between the cable sheath and a hot exhaust pipe and subsequent burning.
- Motor Head
29 Jul 2014 18:25 - 29 Jul 2014 18:27
That spring takes any slack out of the cable, making the lever return against its perch., keeping a bit of freeplay at the push rod to worm gear in the side cover. With a safety switch on your clutch lever, if it didn't return all the way to the perch it may start without the lever pulled in.
Doubt you really need the Kawasaki spring. Ace Hardware or Lowes, or any good hardware store with a selection of springs should have something for about a buck.
Last edit: 29 Jul 2014 18:27 by Motor Head.
- RonKZ650
29 Jul 2014 19:44
Yea, the outer spring along the cable was to keep heat away from melting the cable. It helped quite a bit, but Motion Pro Chinese engineering fully executed a full study and found out conclusively a melted cable does no harm. :sick: Well actually cost cutting went into effect on the Chinese cables, but they work OK. The small spring down at your clutch release mech is questionable as to how much it does. I've never ridden without if, but if I had to wager to guess, I would guess you wouldn't notice $0.02 worth of difference whether it missing or on there.
- jsnabbs
- 1981 kawiKZ440
30 Jul 2014 01:27
Ok so the answer is yes it will work without it.
Because i A. dont have the spring and B. dont have the circlip in above picture, and im sure i didnt lose them, i guess they werent there
30 Jul 2014 05:56
The small spring & cotter pin probably help to keep the clutch cable seated. I wouldn't want to chance the thing becoming dislodged from hitting a big pothole or something. The spring on my bike is ~3/8" x 2-5/16" --- you can probably find one at a good hardware store.
Some genuine oem Kawasaki clutch cables have the protective outer spring, but some genuine oem Kawasaki clutch cables don't. The same goes for Motion Pro cables --- some have the spring, some don't. I'd guess that motion pro adds the outer spring according to whether or not the oem cable had it.
The following user(s) said Thank You: jsnabbs
- jsnabbs
- 1981 kawiKZ440
30 Jul 2014 06:11
Yeah, im going to try and find one, dont like the idea of missing parts.
Any idea what the spring is in metric?
30 Jul 2014 06:36
Multiply the decimal inch equivalent by 25.4 to get mms. 3 divided by 8 x 25.4 = ~ 9 .5 mm
