Engine chain sprocket
- DobbinsCMA
03 Jul 2014 09:45
So I am about to crack the engine case but I never took the engine sprocket and nut off! How do i do this now that the engine is off the frame? How do I keep it from moving in order to loosen the nut?
'80 Kz1000B4
MTC 1075 .375 webcams Mikuni RS34
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
Re: Engine chain sprocket
03 Jul 2014 10:02
This should enable you to loosen that nut (see link below). Ed
kzrider.com/forum/2-engine/491079-front-sprocket#491095
The following user(s) said Thank You: PLUMMEN
- DobbinsCMA
09 Jul 2014 11:23
well I did like they suggested but it still wont budge. I bought a torch and am going to heat it up a little bit. It seems whoever tried to take it off the first time rounded the nut a little bit so it is hard to get a great grip. I sprayed it with some seeping fluid to try to loosen it as well.
'80 Kz1000B4
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
- pete greek1
09 Jul 2014 11:53
Can you post a pic., do the threads look rusty, I'm sure you bent the tabs back,
, are you using a 6 point & NOT a 12 point socket, 12 point is more likely to spin & round off, the nut, some heat will help
Pete
Pete
- DobbinsCMA
09 Jul 2014 14:04
Here are the pictures.
'80 Kz1000B4
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
- pete greek1
10 Jul 2014 10:50
Are you using a long breaker bar ?? you cant get enough leverage with a 1/2 inch socket wrench !!
- DobbinsCMA
10 Jul 2014 12:10
Good point. I totally didnt think about that. Also do you think it would matter what 6 point I use as there are two size options on the bolt? Do you think the bigger one, since it is closer to the sprocket, would be easier?
'80 Kz1000B4
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
- DobbinsCMA
11 Jul 2014 13:50
Is this normal?
'80 Kz1000B4
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
- bluezbike
11 Jul 2014 14:51
I would say ....NO......that bearing race is split and ready to be well and truly retired. I am afraid it's a case splitting situation as those bearings are locked into the case with a half-moon shaped steel locator band....
79 KZ 1000 LTD
The following user(s) said Thank You: pete greek1
- pete greek1
11 Jul 2014 15:22
Bluesbike , I don't see where the race is split
But then, I'm half blind, & don't wear my glasses :laugh: :laugh: :laugh:
Pete
Pete
11 Jul 2014 15:35pete greek1 wrote: Bluesbike , I don't see where the race is split
Pete
Check the area in the yellow circle. Ed
Attachment 00005_2014-07-11.jpg not found
- pete greek1
11 Jul 2014 15:40
Good eye, Ed, I missed that
MY BAD :laugh: :laugh:
Pete
I gotta start wearing my glasses more :laugh: :laugh:
Pete
