- Thank you received: 1
Bogging, Wont rev
- CoreyFord
- Thank you received: 2829
- CoreyFord
- CoreyFord
- MFolks
- Thank you received: 540
- CoreyFord
- CoreyFord
- MFolks
Do you have a shop manual? If not, look at these websites:
Manuals (Some of these websites sell used manuals, just ask)
www.repairmanual.com
www.manualsnmore.com
www.midwestmanuals.com/
www.books4cars.com/
www.repairmanualclub.com/motomanuals/
moto-manuals.com/
www.e-classicbike.com/
www.repairthatmotorcycle.com/manuals/kawasaki.html
www.manualedereparatie.info/en/categorii/kawasaki.html
And:
mbsween.bike-night.com/kz750l3/manual.html
- mopguy
- Thank you received: 168
- littlestoney406
82 KZ550C LTD
83 KZ550C LTD RIP
- Thank you received: 2098
CoreyFord wrote: ... 82 csr 750... will not rev up. idles fine. if you give it the slightest throttle it will rev up to about 1200 rpm if that. give it anymore just bogs down... if you spray starting fluid in the air box it will rev up. I have clear fuel hose on it and see fuel flowing. Just need a direction to go....
if you spray starting fluid in the air box it will rev up -- imo, would indicate that the carb pilot circuit is not yet perfectly clean.
If needed, this link enables downloading a 1982 KZ750 twin manual, which I believe (but am not positive) is same as the carb at hand.
bublicpucket.s3.amazonaws.com/Manuals/ka...llwith80and81sup.pdf
Here's an excerpt from page 133 that addresses the carb pilot circuit:
Would spray pressurized carb cleaner through the pilot passages until the spray squirts through the orifices into the carb bore, and keep spraying until certain that both orifices are perfectly clean and clear.
