- Thank you received: 27
A few questions from a noob Valves 82 KZ750 h3 ltd
- dom2570
1. Lately I have started to notice a few things that have gotten me concerned. I have a tapping or ticking noise coming from the cams. Which leads me to believe my valves need adjusting. A few local shops told me it would be no less than 3 weeks before they could get me in, and I was looking at around $1000 parts and labor...
I decided I will do the job myself. I ordered a valve cover gasket and cam cover end plugs from Z1 and will get the correct shims when I know what I need.
2. The PO drilled out the exhaust (did a shit job), and removed the airbox. I am assuming that the carbs were gone through pretty good, because she starts runs without any fuss. I have noticed that with the choke on, the carb will backfire and that I am getting some poping from the exhaust during deceleration. Could this be caused by my valves needing adjusting?
3. I have never had any problems with the exhaust or engine smoking, but I have noticed that I need to top off my oil every other week. Is this normal? Or could this also be remedied when I get the valves done?
I am going to try and post a video of a semi cold start (didn't get the video to work the first few times) if that will help.
4. I have the clymer and original service manual and have been reading them nonstop. I am a little nervous about cracking my engine open, so any helpful tips as to how to approach the valve adjustment would be great.
Thanks in advance.
video link
Whip it like a mule!
- Beaner242
- Thank you received: 16
1982 KZ1000K LTD Chopper
- dom2570
- Beaner242
Dennis Kirk filters click here
- Thank you received: 1656
- undiablo
- Thank you received: 64
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
- Nebr_Rex
- Thank you received: 300
Are you sure you're not running the bike on choke ( butterflies closed )?
Remember, cam caps are 11 ft/lbs., that's just past finger tight. Strip the
threads and the fun really starts. Also clean and oil the threads.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
- Nebr_Rex
Beaner242 wrote: You can do it. I just did the valves on my bike and its pretty simple. I didn't buy the tool, I just loosened up the cam caps enough to get the shims out. The backfiring could be from those pod filters that are on there. Those cheap filters block the air hole in the carbs. I bought Uni filters and have zero problems. I to have to top off the oil but I figured it was from the leaking gaskets that I just replaced when I did the valves. Go ahead and get the oring for your cam chain tensioner, only couple bucks and then you don't have to worry about it. Mine was hard as plastic when I just replaced it.
The KZ750/4 is shim under bucket.
Your KZ1000 is shim on top.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Nebr_Rex
martin_csr wrote: And as a follow-up to undiablo's reply, on the compression test, if one or more of them are low & adding the oil does not increase the pressure, then it is the valve stem seals.
Not the seals, just the valves them selves.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Beaner242
Thanks Rex, I didn't know that.
The statement was in regards to the oil consumption. I think low compression could be either/or.Nebr_Rex wrote: Not the seals, just the valves them selves.
At any rate, he's got some checking to do.
