- Thank you received: 12
Buzzing/vibrating/rattle from exhaust cam area?
- apbling
21 Jun 2014 18:54 #637454
by apbling
Replied by apbling on topic Buzzing/vibrating/rattle from exhaust cam area?
Anyone got any idea how this happens?
- Thank you received: 2098
21 Jun 2014 19:03 #637457
by Patton
If not already done, would also sniff-test the crankcase oil and examine it for possible gasoline contamination. Actually should have been done immediately upon discovering gasoline inside the airbox, and before starting the engine which risked running with lubrication deficiency due to gasoline diluting the oil.
Replied by Patton on topic Buzzing/vibrating/rattle from exhaust cam area?
apbling wrote: ... in the airbox... My filter was doing backstrokes in about 12 oz of gas....
- apbling
22 Jun 2014 07:45 - 22 Jun 2014 07:45 #637499
by apbling
Agreed Patton. First thing I thought of when gas in air box discovered. I did drop the oil, didn't smell like gas. Is what I show just going to get worse now or can it just be a cosmetic reminder to think about things before you start the bike? I did try and smooth the score and bur with some emery clothe. Nothing too abrasive.
I'd like to also mention bike seems a-ok now though.
Last edit: 22 Jun 2014 07:45 by apbling.
- loudhvx
- Thank you received: 1616
22 Jun 2014 09:11 #637514
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Buzzing/vibrating/rattle from exhaust cam area?
I can't think of a reason for that other than the obvious... a piece of grit got in during maintenance.
I wouldn't worry about it. There's nothing simple to be done about it.
Glad to hear it runs ok now, but why the gas pool? Is the leak fixed?
1981 KZ550 D1 gpz.
Other links.
- apbling
22 Jun 2014 17:50 #637578
by apbling
Gas pool was caused by moron owner leaving petcock on prime while bike sat. That being said, the float needle should stop the flow, but didn't. Also means that maybe I have an overflow plugged too.
