1
  • ojr1979
  • ojr1979's Avatar Topic Author
1
08 Jun 2014 10:07 - 20 Jun 2014 11:13
#635775
1
Last edit: 20 Jun 2014 11:13 by ojr1979.
  • 81-KZ750eTC-01
  • 81-KZ750eTC-01's Avatar
  • Long term,Green Bleeder
Re: Kawasaki z750e gear shift
08 Jun 2014 12:01
#635784
Hello, you are next looking for race bike friend or shop to tig weld a bushing on the case. Any good guy with tig can do it. Also I would remove (Igniter box) from bike when ready for job. Long live the (E) Use a good piece of T6 Alloy for the job, rather than cheap Alloy = longer life repair........Nice to see another suviver........pics of mine I think are on page 33 or 34,.....1 of a kind Turbo........
1975 Mazda Rotary Truck daily driver, KAZU's Dad, 2 big bikes left, 6 RC bikes still.........
The following user(s) said Thank You: ojr1979
  • ojr1979
Re: 1
10 Jun 2014 11:46 - 20 Jun 2014 11:13
#636052
1
  • 81-KZ750eTC-01
11 Jun 2014 10:47
#636158
If it was mine, i'd rather do it in the bike of course+less work. Only trust a weld, J-B IS NOT GOOD for such loading. I would try to find a striipped down block so you can see how much Meat is around that area on other side. It should not warp but a small bit. Just get tack welds 8-10 12 2 4 6 o clock would not heat it so much, give cooling time.... I have had some crazy welds with 30+ year service, caliper brackets...........yellow one is 750 caliper on a 83 YZ-60, And a master cylinder repair.....and triple clamps................take a peak........
