Help Diagnosing extremely high idle
- tdubya84
03 Jun 2014 11:55
Hello out there!
Fist post for a long time lurker. So I've got myself my second 79 KZ650, I couldn't bring my other one with me on the move and found another one while looking for another motorcycle. 1300 for 2 complete bikes, I think I did . . . ok.
But, onto the good stuff. So I got one running! Big accomplishment for me, and done with lots of help from y'all and the problems you faced. So I got her to start but once she starts she revs up real high, with the choke off. Any idea what the deal is?
I've got two videos to help try and diagnose the problem.
Links below:
1-
2-https://www.youtube.com/watch?v=kMDgpfHEr6g
Any thoughts?
Thanks!
tw
Links below:
1-
Any thoughts?
Thanks!
tw
78 KZ650B
- kaw-a-holic
Re: Help Diagnosing extremely high idle
03 Jun 2014 12:03
Congrats on the bikes.
I would suggest that you make sure the choke/enricher is closing all the way. I would then check to make sure the throttle cables are adjusted corrected and well lubed. After that I would check the timing advance mechanism to make sure the weights are moving freely, and of course, well lubed. The Kawasaki service manual has a maintenance schedule/check list that should be gone through completely. It will eliminate most issues.
Nice buy and good luck.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
1977 KZ1000a1
Mesa, AZ
- tdubya84
03 Jun 2014 12:19
I haven't been able to find a FSM for her yet. I've got a Clymer's in VA but from what I've read there are some discrepancies.
I keep seeing digital formats for the bikes for sale on ebay but am unsure about buying one. Anyone have any experience in buying digital FSMs?
Thanks,
tw
Thanks,
tw
78 KZ650B
- peter1958
- Banned
03 Jun 2014 12:42
www.kzzone.com/
- murquiza
03 Jun 2014 12:46
I also believe it might be a vacuum leak. I would start checking that first.
Bikes:
1979 KZ650-D2 SR
2006 Vulcan 2000-A
2006 ZX10R
2008 Versys KLE650
1979 KZ650-D2 SR
2006 Vulcan 2000-A
2006 ZX10R
2008 Versys KLE650
03 Jun 2014 13:06
IMHO using starter fluid or propane isn't the best way to test. The best thing to use is carb cleaner. The reason is rather than the engine revving up, which could be caused by something else, carb cleaner will cause the engine to immediately idle down and/or die if there is a carb holder leak. The key is to temporarily set the idle as low as possible while conducting the test. That causes max vacuum at the carb holders and makes the engine quite sensitive to the carb cleaner. Also, unlike some stuff folks use, like WD40, carb cleaner leaves no residue. Ed
- peter1958
- Banned
03 Jun 2014 13:15
I just figured he had a problem with a vacuum leak and hate typing one letter at a time so looked for a video. I will just stay quiet as usual
www.kzzone.com/
- tdubya84
03 Jun 2014 13:20
It seems there's a vacuum leak. I just replaced the air inlet ducts from the airbox to the carb. Seems the carb holders need to be replaced as well. Just scored a sec off of ebay for 73.00.
I will go through the other items while those are on the way. Thanks everyone!
78 KZ650B
03 Jun 2014 15:18peter1958 wrote: I just figured he had a problem with a vacuum leak and hate typing one letter at a time so looked for a video. I will just stay quiet as usual
:laugh: :laugh: I hope i didn't come off as being too critical; the video was fine. Sounds like you nailed the issue - carb holder leak. Ed
- tdubya84
03 Jun 2014 15:21
Thanks, Pete!
The video was a big help, and I'll bet it'll help plenty others with similar issues.
Only downside is when old videos and photos get taken down leaving the thread bare for the future.
Thanks again to all!
78 KZ650B
