Engine runs and starts but 1&3 not Firing
- zed1015
Re: Engine runs and starts but 1&3 not Firing
25 May 2014 02:46 - 25 May 2014 02:50
If ALL plugs spark and 2 + 4 cylinders run ok it's NOT the timing or coils.
Timing and coils are paired to 1 -4 and 2-3 so if the timing is right for number 1 cyl it has to be right for number 4.
Forget timing and coils.
Cam timing will be ok too so start by looking at fueling especially the pilot circuit , if it's CV carbs look for split diaphragms and then compression but unless you have zero comp due to bent or non seating valves etc there should be some combustion enough to warm the headers.
Also check for split/leaking carb mounting rubbers on those cyls as the engine will draw air rather than fuel if that is the case.
Last edit: 25 May 2014 02:50 by zed1015.
25 May 2014 06:48 - 25 May 2014 06:53pscycle wrote: Check your timing. #1 and #3 are most likely the same coil if not timed properly they wont fire even if they have spark and fuel.
What?! See zed1015 posting above for accurate info. ed
Last edit: 25 May 2014 06:53 by 650ed.
- loudhvx
25 May 2014 09:25
There are 3 or 4 good manuals in my signature.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- pscycle
- MMMMHMMMM
25 May 2014 11:10 - 25 May 2014 11:41
Sorry Daren about the #1 #3 reply it was early am I was half asleep
pscycle927
Last edit: 25 May 2014 11:41 by pscycle.
25 May 2014 17:13 - 26 May 2014 09:19
Daren, I know you said that there's good spark, but I would go ahead & redo the spark plug wire connections at all points. The plug wires are removable from the coils by unscrewing the ribbed compression boots. If the wires have the white crusty oxidation, nip off the ends a tad but not too much. Even if it's not the problem, it's easy. It wouldn't hurt to go ahead & replace the plug wires... assuming they are the original 30-yr old stuff.
My bike was firing intermittently on #1 & #2 but doing the above solved the problem - I though there was good spark -- checked in a darkened garage at night.
Last edit: 26 May 2014 09:19 by martin_csr.
- nedrowjoe
25 May 2014 18:54
check and double check your firing order, I'll admit I ran a bike once I swore the plug wires were right, I knew when I took off, down the road on 2 cylinders i had the wires wrong, double check!
- daren1093251
26 May 2014 08:41
I did triple check and they are all in the correct order. I will try suggestions from other people. Thanks guys for the help I will report back laterwhen I have time to work on the bike.
If you ain't first ; You're last
Current bikes :
2013 Kawasaki KLX250s
1984 Kawasaki KZ550 LTD (Project!)
1985 Honda Aero 85 (Rebuilding!)
Current bikes :
