- Thank you received: 2
Engine runs and starts but 1&3 not Firing
- daren1093251
None the less, I changed the oil, cleaned the carbs (for a bike parked for over 15 years, they weren't as bad as I expected!), they are not PERFECTLY sync'd, but good enough to be able to make her run. Cleaned out the air filter, changed the battery, the plugs and finally checked if they all did spark. All 4 make a nice perfect blue spark.
So heres where i'm stumped ; With full Choke on, the bike starts easily enough, but only piston 2 & 4 make it run. I tried to let it warm up to see if 1 & 3 would kick in, no go. The headers for 2 & 4 are very hot (well, normal heat for a header) and 1 & 3 are cold, like they never even fired.
I didn't get to do a compression check yet, I just ordered today a tester.
If anybody has an idea what would be my issue, it'd appreciated!
P.S. : Carbs are all working and opening fine.
If you ain't first ; You're last
Current bikes :
2013 Kawasaki KLX250s
1984 Kawasaki KZ550 LTD (Project!)
1985 Honda Aero 85 (Rebuilding!)
- Thank you received: 2829
- daren1093251
Current bikes :
- pscycle
- MMMMHMMMM
- Thank you received: 1
pscycle927
- daren1093251
Current bikes :
- pscycle
- MMMMHMMMM
pscycle927
- daren1093251
I guess the timing goes off by itself eventually? The bike was running 15 years ago then it was parked for 15 years. Just wondering, thanks so much guys.
Current bikes :
- pscycle
- MMMMHMMMM
pscycle927
- Thank you received: 2098
- daren1093251
Current bikes :
- loudhvx
- Thank you received: 1616
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- pscycle
- MMMMHMMMM
daren1093251 wrote: Alright the timing it is, can I check the timing with the engine still in the chassis or will I need to take out the engine? I've never done timing work so I might just bring it to a shop. Thanks for the help guys.
pscycle927
