Engine runs and starts but 1&3 not Firing
- daren1093251
24 May 2014 08:51
I'm stumped, I bought this bike for 100$ (1984 Kawasaki KZ550 LTD) from a friend, he had no idea if it ran, what was wrong with it, so I took the chance.
None the less, I changed the oil, cleaned the carbs (for a bike parked for over 15 years, they weren't as bad as I expected!), they are not PERFECTLY sync'd, but good enough to be able to make her run. Cleaned out the air filter, changed the battery, the plugs and finally checked if they all did spark. All 4 make a nice perfect blue spark.
So heres where i'm stumped ; With full Choke on, the bike starts easily enough, but only piston 2 & 4 make it run. I tried to let it warm up to see if 1 & 3 would kick in, no go. The headers for 2 & 4 are very hot (well, normal heat for a header) and 1 & 3 are cold, like they never even fired.
I didn't get to do a compression check yet, I just ordered today a tester.
If anybody has an idea what would be my issue, it'd appreciated!
P.S. : Carbs are all working and opening fine.
If you ain't first ; You're last
Current bikes :
2013 Kawasaki KLX250s
1984 Kawasaki KZ550 LTD (Project!)
1985 Honda Aero 85 (Rebuilding!)
Current bikes :
Re: Engine runs and starts but 1&3 not Firing
24 May 2014 10:43
Are you positive you have the spark plug wires connected correctly? One coil should be attached to cylinders 1 & 4; the other coil should be attached to cylinders 2 & 3. Ed
- daren1093251
24 May 2014 11:49
I just triple checked what you told me, they are infact all correctly connected. The coil to the right control 1 & 4 and the coil to the left controls 2 & 3, unless it's vice versa but by the length of the wires it seems to make sense. Thanks for the suggestion though!
Current bikes :
Current bikes :
- pscycle
- MMMMHMMMM
24 May 2014 12:02
If you have a sprk on all 4 its likely the timing is out of sync does it have points or electronic ignition?
pscycle927
- daren1093251
24 May 2014 13:05 - 24 May 2014 13:20
If you mean Electric start, yes it does. No kickstart. Not too sure what you mean by points, not very knowledgable in the correct terms, specially in english!
Current bikes :
Current bikes :
Last edit: 24 May 2014 13:20 by daren1093251. Reason: fixed a few typos
- pscycle
- MMMMHMMMM
24 May 2014 13:30 - 25 May 2014 11:40
Check your timing. #1 and #4 are most likely the same coil if not timed properly they wont fire even if they have spark and fuel.
pscycle927
Last edit: 25 May 2014 11:40 by pscycle.
- daren1093251
24 May 2014 13:48
Alright the timing it is, can I check the timing with the engine still in the chassis or will I need to take out the engine? I've never done timing work so I might just bring it to a shop. Thanks for the help guys.
I guess the timing goes off by itself eventually? The bike was running 15 years ago then it was parked for 15 years. Just wondering, thanks so much guys.
Current bikes :
Current bikes :
- pscycle
- MMMMHMMMM
24 May 2014 14:15
Yep without a manual and some past expierience your best bet is to take it in. timing is an important issue it should be fairly inexpensive to have checked. good luck
pscycle927
24 May 2014 15:05
Could help diagnosis if test to see whether 1 & 3 kick in with help of starting fluid.
- daren1093251
24 May 2014 15:27
Starting fluid? Down the cylinders i'm guessing or through the air box?
Current bikes :
Current bikes :
- loudhvx
24 May 2014 22:39
Airbox, but have a halon fire extinguisher ready.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- pscycle
- MMMMHMMMM
25 May 2014 01:01 - 25 May 2014 01:09
Im pretty sure your best bet is to take it in to the shop bud ,I would hate to see you get in to deep and cost yourself a headache but if you do want to tackle it find a good manual to explain the procedure and guide you through. It is not really hard but you need a timing light and the understanding of what your doing and trying to accomplish with the light There are some good youtube vids to help you as well..
daren1093251 wrote: Alright the timing it is, can I check the timing with the engine still in the chassis or will I need to take out the engine? I've never done timing work so I might just bring it to a shop. Thanks for the help guys.
pscycle927
Last edit: 25 May 2014 01:09 by pscycle.
