Vance & Hines Performance Baffle?
  • CoolerKing
  • CoolerKing's Avatar Topic Author
10 Apr 2014 11:43
#628569
Does anyone have any experience with V&H Performance baffles? I didn't know if they made a real difference in exhaust note?
www.z1enterprises.com/ItemDetails.aspx?i...+baffle&item=VH21260
1978 KZ650-C2
1976 KZ400D-3 (sold)
  • bLodi
  • bLodi's Avatar
Re: Vance & Hines Performance Baffle?
10 Apr 2014 12:08
#628571
Looks identical to the baffle that came with my V&H and they are saying its a replacement, so it must just be the "stock" V&H one. I usually just run without any baffle though....it's certainly not subtle.
If you have a V&H and don't have a baffle...yes, it will make a huge reduction in the sound.
www.blodisign.com
\\\\\\\'74 Z1
V&H 4-1 Header, Pod Filters, Dyna Ignition, Dyna Coils, Dyna Wires, lowering kit...much more.
  • StreetfighterKz
  • StreetfighterKz's Avatar
10 Apr 2014 16:43
#628602
If you have a baffle, you can do like I did and remove the packing and reinstall the baffle. It makes it louder but isn't obnoxious like an unbaffled pipe is.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • mtkawboy
  • mtkawboy's Avatar
10 Apr 2014 17:18
#628605
I cut all but the last inch of the baffle off and pop riveted the end cap back on along with the existing screw. Sounds good but again not obnoxious like no baffle at all.
  • CoolerKing
10 Apr 2014 17:31
#628607
Thanks, I unwrapped mine, cut the fiberglass in half and then re wrapped it with some tie wire. The performance baffle has a larger diameter center pipe so I didn't know if it would give a deeper note or not.
1978 KZ650-C2
  • fordtruck
  • fordtruck's Avatar
11 Apr 2014 19:25
#628736
I swapped the regular baffle in my V&H for a competition baffle a couple of years ago. It makes it sound much better. It's not obnoxiously loud, but louder than the street baffle. I love it.
'77 KZ1000-MTC 1075 kit. Stage 1 port
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
12 Apr 2014 05:09
#628768
fordtruck wrote: I swapped the regular baffle in my V&H for a competition baffle a couple of years ago. It makes it sound much better. It's not obnoxiously loud, but louder than the street baffle. I love it.
Does this baffle change necessitate re-jetting the carburetors? :unsure:
1982 KZ1100-A2/1170 sleeper 😀
  • KZB2 650
  • KZB2 650's Avatar
12 Apr 2014 14:19
#628812
Stock baffle measures one and an eighth and tappers down slightly from there , so the inch and three quarters should be much more free flowing. If they get them back in I'm thinkin I'm picking one up. I been going without the packing since I first got it too.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • fordtruck
14 Apr 2014 09:10
#628987
As long as you aren't jetted too lean now, I wouldn't think you would need to rejet just from swapping the baffle. I put the baffle in at the same time I rebuilt the motor and put larger carbs on, so I can't compare before and after on the jets.
  • Zedone
  • Zedone's Avatar
15 Apr 2014 15:04
#629144
Here is what I did to mine. I cut @ 5" off of it and made my own end cap using 3/4" 6061 T6 using a router. Its pretty loud but more importantly it flows excellent with my motor/carbs. I think I just got lucky though
1977 KZ1000A1
1977 KZ1000A1 (Superbike Project)
1969 Chevrolet C/10 Short Fleet
  • saxjonz
  • saxjonz's Avatar
  • KawboyZ
15 Apr 2014 17:33
#629162
I'm sure there are two different baffles for VH. One is stock and other is larger which will let bike bark a bit louder but still retains enough back pressure to keep your torque going strong. I personally have the comp baffle in mine. That is a real difference in performance and sound is just a little bit or more louder. You should tune it so it runs to the mods installed. It will still run but a properly tuned set up will make a big difference in the acceleration factor. You'd be surprised at just how much.
79 LTD B3
  • Zedone
  • Zedone's Avatar
15 Apr 2014 19:08
#629179
I forgot to mention, my pipe has been shortened as well. The previous owner shortened it, I had it ceramic coated and added the nameplate along with the endcap. I shd add that my head has been ported with larger valves, bigger cams, a 1200 kit, and RS 36mm Mikuni's. I would not recommend doing this pipe mod to a stock motor in most cases you will wind up losing HP.
Cheers,
Doug
Attachment IMG_2394.jpg not found
Attachment IMG_2484.jpg not found
1977 KZ1000A1
