Guide Roller Damper Rubber dropped in crank case
- Pindar
05 Apr 2014 19:20
Hi Folks,
I know many will frown, but as I was removing the lower cylinder gasket of my KZ650 and removed some cloth I placed to protect the chain guide mouth, one of the two chain guide roller damper rubbers dropped in the crank case.... At least I think, beacause I only noticed one of the two rubbers where missing after the fact... I can't see it in the engine though (although I only have limited visibility)
Roller Damper Rubber: www.partsnmore.com/parts/kawasaki/kz650c...%5Bfitting%5D=custom
The engine is still in the frame and I really don't want to take the whole lower engine out to flip it upside down and get it out. :dry:
Any other remedy recommendations??
Thanks!
Thanks!
Re: Guide Roller Damper Rubber dropped in crank case
05 Apr 2014 20:33
If you drop the oil pan you may be able to find it. Ed
- oldkaw
06 Apr 2014 05:11
I found my rubber dampers in the oil pan when that happened to me. I agree with Ed... good chance it can be found in your oil pan.
2 1984 zn1100, 1 1985 projects
1984 zn700 oil cooler, kerker 4-1, mikuni 34's, k&n pods
1984 zn700 stock
1982 kz750m1 stock
1975 cb550k
1975 cb360t
1984 zn700 stock
1982 kz750m1 stock
1975 cb550k
1975 cb360t
- JimB
06 Apr 2014 05:39
+1. I had one fall right into the oil pan. With the pipes off you can remove the oil pan quickly from underneath while still in the frame. Have a new gasket ready if the oil pan has not been off in some time. Mine was baked on. I used some (a dab) black permatex to "glue" the rubbers on to the metal roller for installation.
1978 KZ1000A2, 1980 KZ1000E, 1980 KZ1000B4 LTD
- zed1015
06 Apr 2014 05:46
Did this myself the other day with one of the upper roller rubbers.
At the most it's just a matter of dropping the sump but if you drain the oil through a strainer with the bike upright there's a good chance they will come out with the oil and you won't have to remove the sump.
- Pindar
06 Apr 2014 05:55
Thanks for all the replies, you guys are great. I'll remove the oil pan and see what happens!
Cheers!
Cheers!
- LarryC
06 Apr 2014 15:32
Actually you should always pull the oil pan when you have the top end off. It's probably coated with black crud and also when you disturb the block, road grit falls down inside. Why not take the time to make sure the oil has a clean house to live in....you're pistons will smile at you for the effort :laugh:
Larry C.
- DFIGPZ
06 Apr 2014 15:34PLUS 1 !!!!LarryC wrote: Actually you should always pull the oil pan when you have the top end off. It's probably coated with black crud and also when you disturb the block, road grit falls down inside. Why not take the time to make sure the oil has a clean house to live in....you're pistons will smile at you for the effort :laugh:
1984 750 Turbo
