79 mk2 shaft to chain
  • fat rider
  • fat rider's Avatar Topic Author
20 Mar 2014 18:57
#625961
i have done this conversion years back anyone know if i need to machine the cases for the shift shaft to fit ?
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: 79 mk2 shaft to chain
20 Mar 2014 20:53
#625973
There is no such thing as a "79 MKll shaft.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • floivanus
  • floivanus's Avatar
20 Mar 2014 21:47
#625982
79 kz1000ST is a mkii style case.
Gotta switch out the trans output shaft, shift shaft and transmission cover.
Past; 78 kz1000, 83 kz550
Andrew
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
21 Mar 2014 07:08
#626010
no machine work.
  • mac0239
  • mac0239's Avatar
23 Mar 2014 11:06
#626248
this can be done? wow
never heard of anyone changing an ST to a chain.
I know with enough time and money you can change anything on almost anything but i wonder how much work and $$$ this would cost a guy to do. kinda curious as i have a shaft ST as well and ok with it but would love a MK11 one day as well....though i know i would prob have to sell my house to afford it as they are so rare now and expensive as a result. maybe it would be cheaper way to go...ha ha.
Green 79' KZ1000st engine-1075 Wiseco kit, k&n pods, dyna ig & coils, and very old Kerker 4 into 1 pipes
Other project- orig Red 79' KZ1000st engine-stock so far with mystery black 4/1 header TBD
23 Mar 2014 11:29
#626254
mac0239 wrote: this can be done? wow
The conversion being addressed is probably about replacing the engine in a chain-drive model with an engine from a shaft-drive model, whereby the engine will be modified to gain a counter-shaft sprocket.
And not referring to replacing the engine in a shaft-drive model with an engine from a chain-drive model in order to convert the shaft-drive model to a chain-drive model (not easy, due to differences in frames and rear suspensions).
Good Fortune! :)
  • mac0239
  • mac0239's Avatar
23 Mar 2014 11:38
#626256
oh ok.
title " 79 mk2 shaft to chain " threw me off i guess.
that being said. still curious if changing a shaftie to a chain is something guys have done and if so at what effort and expense...anyone hear of this?
steve
  • zed1015
  • zed1015's Avatar
23 Mar 2014 14:03 - 23 Mar 2014 14:03
#626278
The ST frame is wider at the swing arm pivot and pretty easy to convert to chain once the gearbox is done but it isn't a case of just bolting in an existing ZED swing arm.
ST frames are particularly sought after when fitting modern swing arms and wider rims due to the extra clearance for the chain run .
Last edit: 23 Mar 2014 14:03 by zed1015.
