Gpz750 oil pan on 79kz650
- Weber
20 Mar 2014 18:17 #625952
by Weber
Gpz750 oil pan on 79kz650 was created by Weber
Does anyone know which year gpz750 pan fits on 79 kz650? Any help with this would be appreciated. Thanks
- Thank you received: 2098
20 Mar 2014 18:44 - 20 Mar 2014 18:45 #625960
by Patton
Replied by Patton on topic Gpz750 oil pan on 79kz650
Info at
www.kawasaki.com
shows oil pan part no. 49034-5011 shared on the following models.
Model (22):
KZ650-B1 (1977)
KZ650-B2 (1978)
KZ650-B2A (1978)
KZ650-B3 (1979)
KZ650-C1 (Custom) (1977)
KZ650-C2 (Custom) (1978)
KZ650-C3 (Custom) (1979)
KZ650-D1 (SR) (1978)
KZ650-D1A (SR) (1978)
KZ650-D2 (SR) (1979)
KZ650-E1 (LTD) (1980)
KZ650-F1 (1980)
KZ650-H1 (CSR) (1981)
KZ650-H2 (CSR) (1982)
KZ650-H3 (CSR) (1983)
KZ750-E1 (1980)
KZ750-E2 (1981)
KZ750-E3 (1982)
KZ750-H1 (LTD) (1980)
KZ750-H2 (LTD) (1981)
KZ750-H3 (LTD) (1982)
KZ750-H4 (LTD) (1983)
Info on kawasaki.com includes parts diagrams, part names, part numbers, models sharing same part, availability, etc. Here's a link for help with navigating the site and finding information.
www.kzrider.com/forum/13-bike-related/37...imitstart=0&start=20
Model (22):
KZ650-B1 (1977)
KZ650-B2 (1978)
KZ650-B2A (1978)
KZ650-B3 (1979)
KZ650-F1 (1980)
KZ750-E1 (1980)
KZ750-E2 (1981)
KZ750-E3 (1982)
Last edit: 20 Mar 2014 18:45 by Patton.
- koolaid_kid
- Thank you received: 99
20 Mar 2014 19:32 #625965
by koolaid_kid
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
Replied by koolaid_kid on topic Gpz750 oil pan on 79kz650
Well, that means it probably will. I am certain the GPz750 fits on a 1981 KZ750E. The only difference is the threaded holes for the oil cooler inputs and outputs.
1983 GPz 750
- Nebr_Rex
- Thank you received: 300
20 Mar 2014 20:51 #625972
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
Replied by Nebr_Rex on topic Gpz750 oil pan on 79kz650
The non turbo GPz750 pan is a direct bolt on. The factory oil lines have o-rings.
If you have to fabricate your own,take that into concideration.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- koolaid_kid
20 Mar 2014 21:46 - 20 Mar 2014 21:47 #625981
by koolaid_kid
1983 GPz 750
True, the connections have flanges with o-rings, don;t they.
1983 GPz 750
Last edit: 20 Mar 2014 21:47 by koolaid_kid.
- Dr. Gamma
- Thank you received: 680
20 Mar 2014 22:04 #625983
by Dr. Gamma
1986 RG500G 2 stroke terror.
Replied by Dr. Gamma on topic Gpz750 oil pan on 79kz650
Back in 1983, I put the oil pan, oil cooler and lines from a 1982 GPZ750 (KZ750R1) on a 1980 KZ750E1 motor.
Everything bolted right up. Same oil pan on Kz650 as KZ750E1, so everything should bolt up to your Kz650.
- Weber
21 Mar 2014 06:31 #626004
by Weber
Replied by Weber on topic Gpz750 oil pan on 79kz650
Thank you for all of this info.....very helpful....!!! Now a mad search for parts
- baldy110
- Thank you received: 512
21 Mar 2014 10:13 #626025
by baldy110
Replied by baldy110 on topic Gpz750 oil pan on 79kz650
