- Thank you received: 1
Question on kerker install, 83 kz750L3
- stilkikin
- Why the **** did I do that?
28 Feb 2014 10:56 #623622
by stilkikin
82 KZ750L
78 KZ650SR
Question on kerker install, 83 kz750L3 was created by stilkikin
My used ebay kerker just came in. I did not get any mounting hardware with it. I went to install the thing and to my suprise the split collars are now not long enough due to the design of the headpipe. I have a lot of play in the pipe and there is no way it will seal like this. Is there a special set of split collars available for this install? I was expecting it to bolt right up, I should have known better. Nothing EVER bolts right up...
82 KZ750L
78 KZ650SR
- Thank you received: 2829
28 Feb 2014 11:04 #623624
by 650ed
Replied by 650ed on topic Question on kerker install, 83 kz750L3
You may want to contact SuperTrapp to see where you can buy the split collars. SuperTrapp owns Kerker. Ed
www.supertrapp.com/company/history.asp
- sbc1320
- Thank you received: 38
28 Feb 2014 11:16 #623625
by sbc1320
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
Replied by sbc1320 on topic Question on kerker install, 83 kz750L3
Either or what Ed says or maybe you can double up on the copper gaskets?
- stilkikin
28 Feb 2014 11:23 #623626
by stilkikin
82 KZ750L
78 KZ650SR
Replied by stilkikin on topic Question on kerker install, 83 kz750L3
Thanks guys, I just contacted Supertrapp and am waiting for an answer. I read on their forums though that it's not available. I contacted the ebay seller as well to see if he has them.
There is an easy 1/2" gap. I beleive I read the kerker ones are 1.25". There is no way doubling the crush washers will work, It would be nice though if it would.
Looking on ebay the kz or gpz 550 collars look about the same length. Does anyone know the diameter of the 550 pipes so I can compare?
82 KZ750L
78 KZ650SR
- Grumpy Ole Artist
- Eschew Obfuscation!
- Thank you received: 62
28 Feb 2014 11:29 #623627
by Grumpy Ole Artist
1978 KZ650 B2
Former rides...1976 CB360T, 1985 Shadow 700, 1985 GPZ750Turbo
Replied by Grumpy Ole Artist on topic Question on kerker install, 83 kz750L3
My new V&H came with longer than stock split collars...was told by a memeber here that my studs aren't going to be long enough..(Jeff S. at Z1E disputed that, however! ) I'm not ready to put them on yet, but hopefully SOME things simply "bolt on"( for ALL of us, LOL!)
Call Z1 enterprises !
1978 KZ650 B2
- Dr. Gamma
- Thank you received: 680
28 Feb 2014 11:34 #623628
by Dr. Gamma
1986 RG500G 2 stroke terror.
Replied by Dr. Gamma on topic Question on kerker install, 83 kz750L3
Check out the 1977/1978 KZ650B, or C model split collars to see how long they are. Those were pretty long split collars compared to the ones on your late model. I am doing this from memory, and have not checked any parts diagrams yet.
- Grumpy Ole Artist
28 Feb 2014 11:39 #623630
1978 KZ650 B2
I don't have any idea whether V&H and Kerker would use the same basic dimensions, but from having seen the Factory 650 -vs- V&H split collars fairly recently I would say the factory ones are about 3/4" shorter than V&H...If it will help. I can measure the two and report back...
1978 KZ650 B2
- stilkikin
28 Feb 2014 11:42 #623631
by stilkikin
82 KZ750L
78 KZ650SR
I've got a set for a 78 kz650d buried somewhere in my parts containers, I'm gonna find them and give them a looksy. Hopefully they will fit.
82 KZ750L
78 KZ650SR
- stilkikin
28 Feb 2014 11:46 #623632
by stilkikin
82 KZ750L
78 KZ650SR
They measure 1.25"! I think they'll work. I'll report back later.
82 KZ750L
78 KZ650SR
- stilkikin
28 Feb 2014 12:39 #623638
by stilkikin
82 KZ750L
78 KZ650SR
The good: They fit perfect.
The bad: I have gorilla arms, and a broken exhaust stud now.
82 KZ750L
78 KZ650SR
- koolaid_kid
- Thank you received: 99
28 Feb 2014 12:40 #623640
by koolaid_kid
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
Replied by koolaid_kid on topic Question on kerker install, 83 kz750L3
Oops. :ohmy:
1983 GPz 750
- Thank you received: 2098
28 Feb 2014 12:50 - 28 Feb 2014 12:53 #623642
by Patton
My understanding is that the thickness of the pipe's end flange against the gasket may vary slightly depending on the particular exhaust system at hand.
For example, the stock exhaust may have a slightly thicker flange than a V&H, whereby the slightly thinner flange would require a commensurately longer split collar.
But the extra length would only be the difference in flange thickness (a very slight amount).
Replied by Patton on topic Question on kerker install, 83 kz750L3
Last edit: 28 Feb 2014 12:53 by Patton.
