Crankcase venting for use on my KZ1000
  • tommyboah
  • tommyboah's Avatar Topic Author
25 Feb 2014 10:45
#623296
I see that my Mikuni RS36 kit comes with a gigantic crank vent hose to be installed along the frame and out behind the rear wheel. The old crankcase breather hose went into the old airbox, which I have now removed in order to run pods with the RS carbs. I was thinking of using a crankcase vent breather filter like this:
Installing it like this:
Will this do, or do i need to route the big ass hose instead? I appreciate any views on this, as I have no experience with this. Thanks.
.Tommyboy
.Tommyboy
  • MFolks
  • MFolks's Avatar
Re: Crankcase venting for use on my KZ1000
25 Feb 2014 10:52
#623298
If it were me, I'd put the filter further from the carbs, as the filter will attract dirt form the oil being expelled via the breather.
  • JR
  • JR's Avatar
25 Feb 2014 13:21 - 25 Feb 2014 13:23
#623313
I used a crankcase filter like that for years when I had pods and never had an issue. It was installed exactly like shown in your photo attachment. I never had oil or anything else come out through that vent
Last edit: 25 Feb 2014 13:23 by JR.
  • DesertKZ
  • DesertKZ's Avatar
25 Feb 2014 13:38
#623314
Same here I run one just like your pic, no issues.
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
  • F1schumie
  • F1schumie's Avatar
25 Feb 2014 14:24
#623320
What's your plans on venting or capping the emissions aka butterfly's on the top of the motor..?
  • peter1958
  • peter1958's Avatar
  • Banned
25 Feb 2014 14:44 - 25 Feb 2014 14:58
#623321
I DON`T THINK THE EURO model has them . This is what I did with my elr
Last edit: 25 Feb 2014 14:58 by peter1958. Reason: add picture
  • RonKZ650
  • RonKZ650's Avatar
25 Feb 2014 16:34
#623334
Those filters look like they could let water in the engine. I've always just got a simple hose and ran it up and back making sure the end is pointing down. I can't see any need to use a filter other than cosmetic looks.
  • zukdave
  • zukdave's Avatar
25 Feb 2014 16:50
#623335
I run a filter like that and I do get oil out of it.
But then my motor spend's most it's running time over 9,000 rpm's.
The more blowby the motor has the more oil you'll
get out of the breather.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
  • peter1958
  • Banned
26 Feb 2014 03:28
#623362
I have run mine both ways. With the filter there its hard to adjust the idle .With the hose back and under its clean.
  • sbc1320
  • sbc1320's Avatar
26 Feb 2014 03:55
#623366
Mine has filter just like that one on it. I like the filter to make sure nothing gets into the line.
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
  • dejavoodo41
  • dejavoodo41's Avatar
26 Feb 2014 08:42
#623378
I had one like that and it fell apart from age I suppose. I had the hose that came with my RS 34's so I used it and ran it up into the tail section.
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
26 Feb 2014 10:27 - 26 Feb 2014 10:30
#623389
tommyboah wrote: Installing it like this:
My bike had the big long tube to the rear fender when I got it, and I replaced it with the setup shown. My K&N filter has a metal post, so I used about 1" of rubber hose to connect the breather tube to the filter. Works great for me.
The only problem I have is that I can't get the hose to stay on the breather tube. Well, I'll say it's very easy to knock off if I'm fiddling with the carbs. The breather tube hose barb is a bit short for a traditional gear clamp and it seem to always want to pop off. Anyone have a clever solution to keep that thing solidly clamped to the breather tube?
My dad's '74 Z1
'00 ZRX1100
Last edit: 26 Feb 2014 10:30 by DOHC.
