Loud Rattling Coming from gearbox
- Chris_Z1100
I've been stuffing around with my 82 z1100 a2 (shaft drive) for a while and i've just started riding on the road again. I've noticed a pretty bad rattling sound coming from the bottom of the engine/gearbox that only occurs at idle. I have little to no experience with shaft drives so i'm not sure at all what's going on in there.
Just wondering if anyone had any ideas what it is before i start tearing it down?
Cheers,
PS i'm new and am trying to add a signiture but it's not letting me save edits on my profile
- Thank you received: 2829
- Chris_Z1100
Cheers,
chris
'82 Z1100 A2
- Thank you received: 2098
Is there combustion on all four cylinders?
Can spray water mist onto exhaust headers shortly after starting cold engine to determine which cylinders are combusting (water vaporizes and sizzles off) and which aren't (water runs down the exhaust pipe).
- Bozo
- Ride it like u stole it
- Thank you received: 105
+1, carby tune to start with (after checking compressions)Patton wrote: Before disassembling anything, would first perform a complete tune-up, including carb sync, then set the idle rpm at 1200.
- baldy110
- Thank you received: 512
- Chris_Z1100
Cheers for the advice, i'll get the carbs synced and set idle and i'll let you guys know how it went.
Thanks!!
'82 Z 1100 A2
- daveo
- Thank you received: 655
Before discovering the culprit, I thought sure something was loose behind the transmission cover.
Somehow my attention arrived at the generator cover. When lightly placing my hand on the cover, I literally felt something wasn't right behind it, with engine idling and the bike on the center-stand. If you try this, do it while the motor is warming up, because that cover becomes very-hot.
This may not be the problem you are having, but it could be.
See: www.kzrider.com/forum/2-engine/540846-oh-brother#540846http://
Good luck...
1982 KZ1100-A2
- Chris_Z1100
- LarryC
Larry C.
- koolaid_kid
- Thank you received: 99
I also suggest that you check your valve clearances prior to the carb synch, as this will affect the synch process.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
- daveo
Chris_Z1100 wrote: Thanks Daveo! felt a bit of a rattle through the alternator cover. Took it off and one of the magnets has cracked. Not sure how though... Would the broken magnet be all that is rattling? It seems pretty small to be making so much noise.
If the magnet piece is loose, it is possible. Post a close-up picture of the broken magnet if you can.
This is likely where the magnet fragments have gone. Pic taken 9/05/10
1982 KZ1100-A2
