Kick Start Mech.
  • 4TheKZ1000
  • 4TheKZ1000's Avatar Topic Author
Kick Start Mech.
06 Feb 2014 17:19
#621366
Can the kick start shaft and gears be removed though bottom of crank case?
I have oil pan off and wanted to remove it, or do you need to split cases for removal?
Thanks, Spencer
  • floivanus
  • floivanus's Avatar
Re: Kick Start Mech.
06 Feb 2014 18:17
#621376
Gotta Split the cases sadly
Past; 78 kz1000, 83 kz550
Andrew
  • 4TheKZ1000
06 Feb 2014 18:25 - 06 Feb 2014 18:44
#621380
I got it out, was very easy......but for "C" clip holding fixed gear. Took me about 25 mins.
Had to weld up a spreader for that c-clip and call on the wife for 2 mins.
This c-clip was a beoutch.......
Attachment kawasaki-1980-kz1000-a4-kz1000-kickstarter-mechanism-79-80-a_bigkar088366357_d03b.gif not found
Last edit: 06 Feb 2014 18:44 by 4TheKZ1000.
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
07 Feb 2014 06:14
#621416
are you saying you removed it "without"splitting the cases ? :huh:
  • turboking
  • turboking's Avatar
07 Feb 2014 06:17
#621417
531blackbanshee wrote: are you saying you removed it "without"splitting the cases ? :huh:
sounds like it........... :unsure:
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
  • 4TheKZ1000
07 Feb 2014 06:56 - 07 Feb 2014 07:13
#621419
Yes, I didn't split the case, and was able to remove the kick start shaft and gears ....
I swear on my Mother's life......no bull.
It can also be put back in with out splitting the case.
There are two retainer clips to remove. #12 and #21. After that, release the tension on the spring, remove spring and plastic bushing and pull out the shaft.
These 8 pieces will slide off the shaft and fall into rear case pocket. # 14 x 2, 15, 18, 19, 20, 21. I used a magnet stick to remove the parts.
No damage to parts.
Last edit: 07 Feb 2014 07:13 by 4TheKZ1000.
  • zed1015
  • zed1015's Avatar
07 Feb 2014 09:49
#621439
Part 13.
The bush that the kicker shaft runs in and is located with a dowel stays in the case when removing the kicker mech in this manner.
  • 531blackbanshee
  • Vendor
  • Vendor
07 Feb 2014 12:10
#621455
sweet!
nicely played sir.
