KZ 400 Shifter Pedal not Returning
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: KZ 400 Shifter Pedal not Returning
11 Feb 2016 03:57
#710387
I'd ask them.
  • Tmiron
  • Tmiron's Avatar
11 Feb 2016 06:18
#710420
Never mind... I re-read their description: "OEM: 92083-021 - Genuine Kawasaki - This is the 3 coil version Fits Kawasaki KZ400/A/B/C/D/S Z1 and a small number of EARLY KZ900's - those up to engine number 95990 ONLY - for over this engine number see 92083-028"
Did you guys get the "Shift Shaft Oil Guide Seal" special tool"
1978 KZ400 B1
  • SWest
  • SWest's Avatar
  • 10 22 2014
11 Feb 2016 07:30
#710428
No, I used a socket to put them in. I have a thread on them. There's three on mine.
  • Tmiron
  • Tmiron's Avatar
12 Feb 2016 14:33
#710613
I couldn't find your thread, mind linking me?
1978 KZ400 B1
  • Olajoe
  • Olajoe's Avatar
  • Free at last
13 Feb 2016 22:39 - 13 Feb 2016 22:55
#710624
I can empathize with your project. I was just in there last week doing maintenance. When you said screws, I had to read this twice. On my bike the pipes have to come off and since those screws didn't want to cooperate it was one of those shake your head, roll your eye moments. Have you considered replacing them with something easier to bolt on and off. I tried to reuse the screws, no way. Interesting that the spring broke where it did. I actually took my spring out just to look at it. If I have these same symptoms later on, I think this thread will help cut to the chase.
Last edit: 13 Feb 2016 22:55 by Olajoe.
  • SWest
  • SWest's Avatar
  • 10 22 2014
14 Feb 2016 05:45
#710644
Tmiron wrote: I couldn't find your thread, mind linking me?
I was responding to this when the site went down.
kzrider.com/forum/2-engine/599659-chain-...-tranny-seals#689802
I hope you read this before you try to put them in.
  • Tmiron
  • Tmiron's Avatar
16 Feb 2016 09:07
#710912
Thanks Steve. So basically, just push it in with a deep socket?
1978 KZ400 B1
  • SWest
  • SWest's Avatar
  • 10 22 2014
16 Feb 2016 09:09
#710914
Yeah, tap them in. Use a smear of grease on the ones with metal inside. The all rubber ones you want to bond so keep them and the case clean.
  • Tmiron
  • Tmiron's Avatar
24 Feb 2016 11:54
#712332
Got everything back together and now it won't start :( I posted here:
kzrider.com/forum/2-engine/601348-won-t-...g-shift-pedal-return
Any and all ideas are appreciated.... I just want to ride!
1978 KZ400 B1
