APE K410
  • The Banned
  • The Banned's Avatar Topic Author
APE K410
28 Jan 2014 10:18
#620344
Just shipped my head to Joe Hooper at PSP...what an amazing guy when it comes to be customer polite.
Anyway- gonna have a Stage 1 porting and was recommended the APE K410 cams because im running 1197cc Wisco Pistons
Anyone tried the K410 cam- how does it run from idle and up through the RPM's
/Lars
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
Re: APE K410
28 Jan 2014 10:24 - 28 Jan 2014 17:52
#620345
It depends how you set the up.
Read up on lobe center. Most run cams between 108 - 110
www.webcamshafts.com/
Last edit: 28 Jan 2014 17:52 by 4TheKZ1000.
  • The Banned
Re: APE K410
28 Jan 2014 10:44
#620346
at the moment i have a set of WM33 i'll try on, but if they dosnt work properly i'll go for the Mikuni TMR
(just need to dig DEEP in my pocket)
Exhaust is 38mm header
So that will be the first set-up
  • 4TheKZ1000
Re: APE K410
28 Jan 2014 11:07
#620348
Well the 33's will handle that setup.
Just remember, a good Kaw engine should start with a great head.
  • The Banned
Re: APE K410
28 Jan 2014 11:51
#620352
Joe is gonna put new valves and make the porting etc, and from what i can read he is one of the best.....so hope its gonna be a great head :)
but do you know anything about the cams ?? from what i can read/told they are good midrange??
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
Re: APE K410
28 Jan 2014 17:50
#620395
Those should be good cams. They will like the higher RPMs but should do good riding is traffic and stop and go traffic.
  • 4TheKZ1000
Re: APE K410
28 Jan 2014 17:56 - 28 Jan 2014 18:29
#620396
The lower duration of the cam, the more midrange. Low duration cams have a sharp lobe point to them.
The more duration of the cam, the more top end. High duration cams have a rolling or more rounded lobe.
You will find duration of cams from 246 degrees all the way to 280 degrees.
As compression rises, so should the duration.
My personal view, I wouldn't go higher than .387 lift on a 1075 to 1105. Anything after that is a waste in 95% of the engines built.
Last edit: 28 Jan 2014 18:29 by 4TheKZ1000.
  • sbc1320
  • sbc1320's Avatar
Re: APE K410
28 Jan 2014 18:20
#620398
The Banned wrote: Joe is gonna put new valves and make the porting etc, and from what i can read he is one of the best.....so hope its gonna be a great head :)
He does good work, he did my last head a few years back on a 76 KZ900.
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
  • saxjonz
  • saxjonz's Avatar
  • KawboyZ
Re: APE K410
28 Jan 2014 20:18
#620408
I have the .410 cams in my bike. As for power, yes, seems like more all around. They pitted a little after 10k miles. I have no idea if that is the norm or if my engine wasn't built right. I ran this with 29 smoothbores and a 1075 kit. Replaced cam that pitted and this time around running liska rollers and a heavy duty chain and solid pieces in the timing chain area. Did more head work and had head ported to fit J boots with 31 keihin cr specials. Sounds like this may be a great ride, just have a few more pieces to put on to finish bike. Be ready for spring. I think those are a nice grind. Didn't notice any loss of power anywhere, all balls all the way to redline. I didn't notice any flat spots at all.
79 LTD B3
  • The Banned
Re: APE K410
29 Jan 2014 02:48
#620423
thansk- some good reply's - keep em' coming :-)
