KZ750F Cylinder Measurement Question
23 Jan 2014 07:41
Used a bore gauge on my cylinders last night. Engine only has 10k miles on it, but has some odd looking wear in the bores.
Factory service manual calls for measuring at three locations, top, middle, and bottom, so did that, including measuring at 90 degrees at each location for a total of six measurements.
Spec is 66mm bore (2.5985"), and max is 66.1mm, with no more than .05mm (.0020") difference between any of the measurements.
Good news is out of round and taper for all cylinders is under .0010".
Bad news is all cylinders measured under nominal by between .0013" to .0026", Measuring at the very top and bottom of the cylinder, where the piston doesn't even swipe, showed most points at .0010" below nominal. So that's my quandry: is it normal to have the cylinders measure so far under nominal?
Need to measure the pistons next to determine piston to wall clearance but clearly, it's going to be about .002" above the nominal level.
Anything to be concern with here? Was planning to bottle brush hone the cylinders and keep running. Was originally planning to reuse the rings, but leaning toward replacing them now.
- Nebr_Rex
Re: KZ750F Cylinder Measurement Question
23 Jan 2014 17:04
If you're worried about it use a rigid hone.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
23 Jan 2014 17:39Nebr_Rex wrote: If you're worried about it use a rigid hone.
Was under the impression that you bottle brush hone used cylinders. If the out or round or taper is above spec, you need to bore to the next size.
Wrong?
23 Jan 2014 20:29
