Big Bore Kit
  • jeffasaki
  • jeffasaki's Avatar
Re: Big Bore Kit
27 Jan 2014 18:09
#620288
1197 with a proper lap on the valves
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
  • baldy110
  • baldy110's Avatar
Re: Big Bore Kit
27 Jan 2014 18:14
#620289
Why were you running a copper head gasket?
  • jeffasaki
Re: Big Bore Kit
27 Jan 2014 18:45
#620295
:laugh: B)
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
  • wireman
  • wireman's Avatar
Re: Big Bore Kit
27 Jan 2014 18:49
#620296
4TheKZ1000 wrote: On the topic of big bore, I know that a stock 1015cc cylinder can go to 1105 ..... might be thin on sleeve.
What can a stock GPZ 1100 head be maxed at?
stock 1100 sleeves can go 1166/1170
  • jeffasaki
Re: Big Bore Kit
27 Jan 2014 19:00
#620297
1197 = 11.5 to 1
street max
for a air cooled motor
cams make all the difference
KAWASAKI1111111111111
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
  • jeffasaki
Re: Big Bore Kit
27 Jan 2014 19:44
#620307
i meant to say KAWAWSAKI
72 new york steak
im trying
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
  • JimB
  • JimB's Avatar Topic Author
Re: Big Bore Kit
27 Jan 2014 19:50
#620308
baldy110,
I was using a one piece copper head gasket because the two piece fiber I put in prior to the rebore was leaking in the front so I figured I would try something different.
Jim
1978 KZ1000A2, 1980 KZ1000E, 1980 KZ1000B4 LTD
  • JimB
Re: Big Bore Kit
06 Feb 2014 09:55
#621325
OK,...so I am ready to put the cylinder and head back on the bike. I decided I am going to go with the one piece fiber head gasket.
Has anyone used the high temp copper permatex to fill the cam chain o-ring area.? That is what I am planning on using and just wanted some feedback.
Jim
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: Big Bore Kit
06 Feb 2014 12:02
#621334
i have no experience with the particular goo you are talking about.
but,it is basically just space filler so anything that sets up will work.
  • NakedFun
  • NakedFun's Avatar
Re: Big Bore Kit
06 Feb 2014 12:52 - 06 Feb 2014 12:53
#621340
I wonder if the sound along with low compression is/was leaking head gasket? It would give a whoosh sound that could be what you are hearing. Thinner between cylinders, warpage on head or cylinder deck....etc. Copper head gaskets take a certain way of torquing, then re torquing after run in. Would account for everything you saw....Just my .02....
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
Last edit: 06 Feb 2014 12:53 by NakedFun.
  • LarryC
  • LarryC's Avatar
Re: Big Bore Kit
07 Feb 2014 05:05
#621411
A leak down tester would have pinpointed the compression problem & they are not expensive. If you like to work on motors, treat yourself to proper tools.
Larry C.
  • gpz1170
  • gpz1170's Avatar
Re: Big Bore Kit
07 Feb 2014 10:02
#621442
also if you are using a copper head gasket and the cylinder is not O-ringed it will probably leak
don
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
