ceramic coated pistons
- tomsbadkz
17 Jan 2014 15:50
Just tryin to get a little feedback on ceramic coating on pistons. The guy that's helping me with my motor recommends having it done. doin a 1327 kz motor. whats your ideas? thanks
1977 kz1327
Cavanaugh Head 38.6/33
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
- jeffasaki
Re: ceramic coated pistons
17 Jan 2014 16:49
there was a member named okatar that used to be into that shit
search posts under that name
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
17 Jan 2014 17:02 - 17 Jan 2014 17:04
You may want to check these folks out. Ed
swaintech.com/
swaintech.com/race-coatings/motorcycle-c...oatings-price-sheet/
swaintech.com/
Last edit: 17 Jan 2014 17:04 by 650ed.
- tomsbadkz
17 Jan 2014 17:28
Swain is the one my motor guy suggested. I was on their site earlier. cool. yea, im just seeing what people say about stuff like this. my motor guy has been doin this for about 25 years, I think he said. Smart guy. thanks for the imput.
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
20 Jan 2014 08:30
ceramic coating the domes is insurance against leaning out and burning a piston.it also helps reflect the heat so it goes on out the exhaust.
it is typically done along with teflon coated skirts,
which is like putting roller bearings on the skirts of your pistons.greatly reduces the friction between the skirt and the cylinder wall.
i do it on all the pistons a can.and would recommend it for any engine.
all good no bad,not many of those in the performance engine world.
hth,
hth,
- tomsbadkz
20 Jan 2014 12:49
thanks for the imput Leon. gonna order my pistons from Joe Hooper and then send them out. as you have probably read, my motor guy says that Swain is the place. I like getting feedback the guys on here. The guys and this forum and awesome. thanks
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
26 Jan 2014 09:59 - 26 Jan 2014 09:59
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationI just noticed that some of the KZ1000 Police and ELR pistons were coated on top. There must be something to it. Ed
Last edit: 26 Jan 2014 09:59 by 650ed.
- steell
26 Jan 2014 14:26 - 26 Jan 2014 14:27
A friend asked a major engine builder about Teflon coating piston skirts. The engine builder said if you're having problems with your eggs sticking, then Teflon would probably help.
True story
True story
Last edit: 26 Jan 2014 14:27 by steell.
