Complete Cluth Assembly Brand New Parts.
  • 4TheKZ1000
  • 4TheKZ1000's Avatar Topic Author
09 Jan 2014 09:48 - 09 Jan 2014 09:58
#617921
Well the Japanese are punching out inner clutch hubs. The only problem is you have to buy the entire setup.
Thought I would post item for inspection. It's about $ 700.00
japan.webike.net/products/1523187.html
Attachment untitled.png not found
Last edit: 09 Jan 2014 09:58 by 4TheKZ1000.
  • Dr. Gamma
  • Dr. Gamma's Avatar
Re: Complete Cluth Assembly Brand New Parts.
09 Jan 2014 11:18
#617933
Looks like a J model style outer basket with the removable inner bushing.
1986 RG500G 2 stroke terror.
  • 4TheKZ1000
09 Jan 2014 12:48 - 09 Jan 2014 12:51
#617949
Dr. Gamma wrote: Looks like a J model style outer basket with the removable inner bushing.
____________________________________________________________________
good eye gamma, read the description:
Description
Kit Contents
Housing COMP, hub ASSY, operating plate ASSY, friction plates, steel plate, push rod, thrust washers, radial bush, mount washer All-in-one package kit to convert SUPER 900 model ( up to the year 1972-80, previous Z series 750 / 900 / 1, 000cc vehicle ), to genuine clutch parts, a succeeding model of Z1000J. Compared to previous Z series steel housing, improves response and significantly reduces friction when operating super light-weight aluminum housing and making ball bearing effect of operation plat. By incorporating genuine new parts of succeeding model, dramatically increases the reliability around clutch area. Complete bolt on design available to mount without modification.
Last edit: 09 Jan 2014 12:51 by 4TheKZ1000.
  • zed1015
  • zed1015's Avatar
09 Jan 2014 13:15
#617955
Yes! Make your clutch more prone to wear with an alloy basket :huh:
Rest of it is nice though and price is ok too.
  • gpz1170
  • gpz1170's Avatar
10 Jan 2014 10:54
#618123
not sure when using the KZ trans with a "J "clutch assembly how the clutch push rod would work since there are a couple of differences, usually we replace the "J "with a KZ since the basket is the weak link on a "J"
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
  • turboking
  • turboking's Avatar
10 Jan 2014 11:05 - 10 Jan 2014 11:07
#618125
B) No thanks ...I've seen too many aluminum baskets blown up on engines with High H.P.. I don't care if the steel (OEM) take more h.p. to spin.......... I can always turn the boost up........ B) B)
:( :( i will stick with the trusty steel oem basket with heavy springs and welded rivets :blink:
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
Last edit: 10 Jan 2014 11:07 by turboking.
  • Dr. Gamma
10 Jan 2014 11:09 - 10 Jan 2014 11:11
#618127
gpz1170 wrote: not sure when using the KZ trans with a "J "clutch assembly how the clutch push rod would work since there are a couple of differences, usually we replace the "J "with a KZ since the basket is the weak link on a "J"
Yea, I have taken apart many a "J'" and GPZ 1100 where the only thing left of the clutch was the outer gear, inner basket, the steel plates, and half of the pressure plate!!! These were all street bikes, not drag bikes.
NEVER have I seen a KZ outer basket come apart. Seen a few where the dampner springs became loose, but thats about it!!!
Thats one thing I miss about not working in a dealership. When the mechanic comes up front laughing, and saying you ain't going to believe this, you got to come look at this!!!! I miss a good laugh once in a while!!!
Last edit: 10 Jan 2014 11:11 by Dr. Gamma. Reason: added something
