Getting new front forks- 81 kz750
- lancekyser14
07 Jan 2014 13:17
So I have been thinking about ditching the stock forks on my kz750. What do I need to know about changing the front forks? I want newer, higher performance forks, probably something I will get from eBay from a newer model bike. Any info provided is greatly appreciated. Thanks fellas!
Lance Kyser
Re: Getting new front forks- 81 kz750
08 Jan 2014 06:20
front end swaps are common.typically using late model zx,gsxr stuff.
sometimes you can find conversion bearing kits from all balls, sometimes it requires some machine work and a stem swap.
the overall length of the leg and wheel together is what you need to pay attention to as most of the late model stuff is a little shorter and the wheels will be 17's instead of 18/19 inch wheel.
- lancekyser14
08 Jan 2014 07:06
Any sites in specific I should check out for those kits? Also when shopping for these new forks, do I need to shop for triple trees as well?
Lance Kyser
08 Jan 2014 09:43
you are on one of the best sites for front end conversions for kz's.
go back through the project pages.
you want to buy as complete of a front end as possible.that way you have all the pieces to make it work.
triples ,legs,brakes,wheel etc.
www.allballsracing.com/index.php/forkconversion
The following user(s) said Thank You: StreetfighterKz
