- Thank you received: 44
Big Block KZ heat
- tomsbadkz
29 Dec 2013 13:40 #616636
by tomsbadkz
1977 kz1327
Cavanaugh Head 38.6/33
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
1984 GPZ1100
Cavanaugh Head
1170cc
Web 415 cams
RC Hp Inj.
Bored throttle bodies
Big Block KZ heat was created by tomsbadkz
I know that when I had my 1385 kz several years ago, it ran fairly hot. with doing another one, I was wondering if it would make much difference with wrapping the header if it would make a significant difference with the heat from the header to the cylinder. there wasn't much talk about the wrap on the pipes when I had the other bike. please chime in. trying to get some new ideas on this bike that would be improvements from what I had before. thanks.
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
1984 GPZ1100
Cavanaugh Head
1170cc
Web 415 cams
RC Hp Inj.
- 4TheKZ1000
- Visitor
29 Dec 2013 13:44 - 29 Dec 2013 13:57 #616637
by 4TheKZ1000
Replied by 4TheKZ1000 on topic Big Block KZ heat
I heard the wrap will help with reflective heat from the pipe some 50 deg.
The wrap will also hold moisture to the pipe and cause rust.
Last edit: 29 Dec 2013 13:57 by 4TheKZ1000.
- 80B4
- Thank you received: 105
29 Dec 2013 13:54 #616639
by 80B4
1980B4 1000
1978 Z1R
1978 B3 750
Replied by 80B4 on topic Big Block KZ heat
I don't think header wrap will help with the heat from a 1385. Look into a big oil cooler, spot on jetting and Redline full synthetic oil.
1980B4 1000
1978 Z1R
1978 B3 750
- tomsbadkz
29 Dec 2013 13:54 #616640
by tomsbadkz
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
1984 GPZ1100
Cavanaugh Head
1170cc
Web 415 cams
RC Hp Inj.
Replied by tomsbadkz on topic Big Block KZ heat
crap. I never thought about moisture issues. I had the pipe on the other bike done by HPC. I thought the wrap would help. its cheaper to replace a pipe every so many years instead of pistons and other victims of heat.
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
1984 GPZ1100
Cavanaugh Head
1170cc
Web 415 cams
RC Hp Inj.
- 4TheKZ1000
- Visitor
29 Dec 2013 14:04 - 29 Dec 2013 14:07 #616642
by 4TheKZ1000
On the cool down after a ride there are condensation issues with the wrap.
Also if wrap gets wet it will hold the moisture to the pipe just long enough to cause rust.
I guess on the big blocks, you just need to keep them in the wind and never sit with bike at idle for a long time.
I have a friend with a 1327 that smoked his valve seals sitting at a stop light............ :blink:
Last edit: 29 Dec 2013 14:07 by 4TheKZ1000.
- tomsbadkz
29 Dec 2013 14:26 #616645
by tomsbadkz
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
1984 GPZ1100
Cavanaugh Head
1170cc
Web 415 cams
RC Hp Inj.
I have a brand new Derale oil cooler. The synthetic oil would help too. maybe the 1327 wont create as much heat as the 1385. The 1385 was a 11.1 to 1 compression. the 1327 is gonna stay around 10.5 to 1. im using a 83-84 gpz1100 head. it's gonna breathe!!!!!!!!!
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
1984 GPZ1100
Cavanaugh Head
1170cc
Web 415 cams
RC Hp Inj.
- Powerstroke_fan
- Thank you received: 83
29 Dec 2013 15:23 - 29 Dec 2013 15:26 #616651
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Replied by Powerstroke_fan on topic Big Block KZ heat
The lower compression will reduce alot of heat. Iam around 9 to 1 compression. The hottest i saw my bike was around 430 degrees. That was running a 12 row tru cool cooler. Now i am going to be running a 13 row earls oil cooler. Iam running a ported j model head on a kz bottom end. Like 4thekz1000 said the key is to keep the wind moving and minimal idling time. I know my hottest times would be at lights on hot days. i purchased the cheap but effective trail tech cylinder head temperature guage. It just goes under your spark plug. Also i run shell rotella T oil.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Last edit: 29 Dec 2013 15:26 by Powerstroke_fan.
- DFIGPZ
- Thank you received: 122
29 Dec 2013 15:29 #616654
by DFIGPZ
1984 750 Turbo
Replied by DFIGPZ on topic Big Block KZ heat
No matter what you do a big block on the street is going to create heat that being said ceramic coating heater helps pull some heat away, proper jetting a must, the largest oil cooler you can run, proper ignition timing a must [ intial & advance. ] synthetic oil helps I prefer Amsoil with that being said prolonged idling etc is going to create heat with the big block not having air flow through the center is the biggest issue.
1984 750 Turbo
- tomsbadkz
29 Dec 2013 18:02 #616664
by tomsbadkz
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
1984 GPZ1100
Cavanaugh Head
1170cc
Web 415 cams
RC Hp Inj.
that's right, the center is open on stock cylinders. I may look for a bigger cooler than the little Derale cooler I have.
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
1984 GPZ1100
Cavanaugh Head
1170cc
Web 415 cams
RC Hp Inj.
- Powerstroke_fan
30 Dec 2013 05:49 #616707
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Are you going to be running a aftermarket big block? or a stock modified block? Earls makes a really nice 13 row curved cooler for motorcycles.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- tomsbadkz
30 Dec 2013 07:45 #616721
by tomsbadkz
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
1984 GPZ1100
Cavanaugh Head
1170cc
Web 415 cams
RC Hp Inj.
Its a Wiseco big block with sleeves I got from MTC. im gonna look at that cooler. thanks
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
1984 GPZ1100
Cavanaugh Head
1170cc
Web 415 cams
RC Hp Inj.
- 4TheKZ1000
- Visitor
30 Dec 2013 09:06 - 30 Dec 2013 09:07 #616727
by 4TheKZ1000
I installed the Earls 13 row cooler on mine. I don't have any numbers to share with it and without. Old Man Rock does have numbers on cooler effect. If I rem correctly......it helped quite abit.
You might want to PM him for stats.
Last edit: 30 Dec 2013 09:07 by 4TheKZ1000.
