1170cc bore kit
  • steell
  • steell's Avatar
Re: 1170cc bore kit
17 Jan 2014 17:13
#619021
Puffin wrote: Alig A piston kit on its own wont give you much of a HP hike. Expect rather an increase in Torque B) If the crank is in good order then i suppose the planned use of your KZ will determin if you need it welded crank or not
An increase in torque without a corresponding increase in hp? I'd love to hear you explain that one.
Aw, I'll give you a break. torque x rpm / 5252 = HP
So any increase in torque automatically increases hp.
You can thank frozen Margaritas for the free ride :laugh:
  • jeffasaki
  • jeffasaki's Avatar
Re: 1170cc bore kit
17 Jan 2014 17:29
#619026
BIULD it as strong as you like run the shit out of it then fix what breaks
its the only way to know for sure
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
