1170cc bore kit
- alig666
1170cc bore kit
26 Dec 2013 14:54
Hi could anyone advise me on an 1170 cc bore kit I was just wondering would the original crankshaft take the strain of the extra compression or would it be better to get my crankshaft upgraded new bearings etc thanks
82 kawasaki kz1100
07 aprilia rsv tuono
80 honda cd200
00 honda nsr125r
80 honda cd200
00 honda nsr125r
- DFIGPZ
Re: 1170cc bore kit
26 Dec 2013 16:05can it take it MAYBE would it be wise NO best off to have crank redone and welded what are we working on KZ, J , GPZ1100 ?alig666 wrote: Hi could anyone advise me on an 1170 cc bore kit I was just wondering would the original crankshaft take the strain of the extra compression or would it be better to get my crankshaft upgraded new bearings etc thanks
1984 750 Turbo
The following user(s) said Thank You: alig666
- alig666
Re: 1170cc bore kit
02 Jan 2014 11:30
It's an 82 kz1100 shaft with 50000 miles on it I think your right would rather do it properly stripped engine to fix couple of oil leaks to find flywheel magnets broken up and stator destroyed so stripped bottom end to clean out was very surprised bike never missed a beat they were built to last ! Thanks for the help
82 kawasaki kz1100
80 honda cd200
00 honda nsr125r
80 honda cd200
00 honda nsr125r
- 4TheKZ1000
Re: 1170cc bore kit
02 Jan 2014 12:16
WHOOOOO,
1170 on a shafty............is this the setup you are going to run?
- alig666
Re: 1170cc bore kit
02 Jan 2014 12:23
Yeah hopefully it's blowing oil past the rings so was thinking about it and asking what you all thought
82 kawasaki kz1100
80 honda cd200
00 honda nsr125r
80 honda cd200
00 honda nsr125r
- 4TheKZ1000
Re: 1170cc bore kit
02 Jan 2014 12:42 - 02 Jan 2014 12:52
No eBay APP ID and/or Cert ID defined in Kunena configurationI'm a bit concerned about the shaft drive mech having trouble holding the additional power?
I would get it right on the crank. With 50K worth of miles, it could be tired.
I would run a welded crank.
I saw a MKII welded crank that accepted index rod on ebay.
Last edit: 02 Jan 2014 12:52 by 4TheKZ1000.
- alig666
Re: 1170cc bore kit
02 Jan 2014 13:39
Yeah not worth taking the chance on the crank will definitely get it welded . Id maybe be better to get and smaller size piston kit dont want to put to much pressure on the differential though it seems to be well made . How much horse power would you think It would make as 1170 they were 102 hp when new appreciate your help thanks
82 kawasaki kz1100
80 honda cd200
00 honda nsr125r
80 honda cd200
00 honda nsr125r
- wagonmaster69
- 78 KZ1000A2 / 82 KZ1100 Spectre
Re: 1170cc bore kit
06 Jan 2014 00:05
I'm watching this one I have a 82 Spectre.
- DFIGPZ
Re: 1170cc bore kit
06 Jan 2014 11:48
Watch using the MK11 Crank it is set up for a peanut style cam chain your bike has a hyvo chain if by chance you end up needing a crank I have a brand new "J" model crank Brand new in Kawasaki box.
Barry
Barry
1984 750 Turbo
- Z1Driver
- love the smell of triple smoke
Re: 1170cc bore kit
06 Jan 2014 18:05 - 06 Jan 2014 18:204TheKZ1000 wrote: I'm a bit concerned about the shaft drive mech having trouble holding the additional power?
A well deserved question....I know this is not the same bike, but I know of a couple of fellows who turbo'ed their ZG 1000's (Concours) and have had no trouble with their drive shafts. I know of 1 guy who turbo'ed his ZG 1400 (Concours) and has had no problem with his drive shaft.
I know of one guy who ported the head on his ZG1000 and had his cams reground for power. I understand his bike will wheel stand on command. ( this guy sells re ground cams for the C10 or ZG1000 is well known and respected in the community. He has had no reported problems with his drive shaft. Plus shafties don't do wheel stands any way right?
I also know one guy in person who put a 1200 cc motor in his ZG1000 frame and was able to use the shaft drive components from his ZG1000 motor. He has had no problems with his drive shaft.
The only drive shaft problems I am aware of in the C10/C14 communities is in 2010, there were some C14's released with out C clips installed on the universals from the factory. That little deal caused some havoc on those bikes.
Blue 1975 Z1B
Red 2009 Concours 14
Last edit: 06 Jan 2014 18:20 by Z1Driver.
- gpz1170
Re: 1170cc bore kit
07 Jan 2014 10:43
If you wanted to change gear ratios, you couldn't. Otherwise should be no problem.
don
don
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
- Puffin
Re: 1170cc bore kit
13 Jan 2014 02:52
Alig A piston kit on its own wont give you much of a HP hike. Expect rather an increase in Torque
If the crank is in good order then i suppose the planned use of your KZ will determin if you need it welded crank or not
KZ1000 J Long Term Owner
KZ1100
KZ1100 Spectre project
KZ1100
