Alternator rotor for Z1R
- Bozo
- Ride it like u stole it
23 Dec 2013 06:01
My alternator rotor that is located on the left hand side of the crankshaft is starting the come loose on the shaft pivot. I believe this a common problem (especially over 206Kkms). Anyway the OEM appears to be obsolete but there is a replacement that looks like a machined housing and is cheaper.
Has anyone used one of these before? if so, what do you think of it?
www.regulatorrectifier.com/catalog/1977-...Z1000-Flywheel-Rotor
- stevemcb
Re: Alternator rotor for Z1R
24 Dec 2013 06:04
fitted this one last year to my Z900, no problems, works fine.
www.electrexworld.co.uk/acatalog/RO99.html
- sbc1320
24 Dec 2013 07:05
Both of those appear to be the same part number.
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
- Bozo
24 Dec 2013 14:43sbc1320 wrote: Both of those appear to be the same part number.
Thankyou, thats all I needed to know - Merry Xmas
- DFIGPZ
26 Dec 2013 16:13is this for 1978 Z1R or 1980 ? I believe 1978 took early small taper version and 1980 took later large taper version I am pretty sure I have a couple of the early version small taper if you are in need.Bozo wrote: My alternator rotor that is located on the left hand side of the crankshaft is starting the come loose on the shaft pivot. I believe this a common problem (especially over 206Kkms). Anyway the OEM appears to be obsolete but there is a replacement that looks like a machined housing and is cheaper.
1984 750 Turbo
- Bozo
04 Jan 2014 04:42
DFIGPZ - Sorry, just got back from my holidays, I have the 1978 model. Joe Hooper from Pitstop has someone helping me so with some luck I should be able to find an original replacement. Thankyou for the offer.
- Powerstroke_fan
04 Jan 2014 10:05
As stated the mk11 motors have a diffrent alternator and rotor compared to kz 900/1000s.
1977 KZ 1000 work in progress
- DFIGPZ
05 Jan 2014 17:07no problem let me know if i can help.Bozo wrote: DFIGPZ - Sorry, just got back from my holidays, I have the 1978 model. Joe Hooper from Pitstop has someone helping me so with some luck I should be able to find an original replacement. Thankyou for the offer.
1984 750 Turbo
- ZERO
06 Jan 2014 09:01
I have several good, used ones... You'll need to lap them on the shaft, first for a good fit. I remove the dowel key and spin them with a little valve compound. Once the area is gray, rinse with brake clean and reinstall the rotor and the key. The "73-78 is the same and pretty much are indestructable, unless they get loose.
Only Kawasakis have a soul 1977 Kawi KZ1000 special 2000 Kawi ZRX1100
