- Thank you received: 1
trouble reinstalling crank in kz1000
- kamakazie1000
18 Dec 2013 09:36 #615812
by kamakazie1000
Terminal lance corporal of Marines, putting the GRUNT in disgruntled
kz1000 cafe project
trouble reinstalling crank in kz1000 was created by kamakazie1000
Greetings kzr community.
im finally starting to rebuild the motor on my 77 kz1000. the motor has been disassembled for a while and sitting. the crank was stored indoors and wrapped with oily rags. I installed the ape main bearing studs into the upper case, but when I tried to install the crankshaft I couldn't for the life of me get the holes on the bearings to fall into place over the dowel pins in the case. I set the crank in the upper case and rotated each outer race until it lined up but I couldn't get all of them to fall in. are there any tips or tricks or maybe something simple that I'm missing, or is this a tell tale sign that I have a bent crankshaft. before tearing the motor down it spun freely and had good compression.
Thanks for the knowledge gents
kz1000 cafe project
- zed1015
- Thank you received: 1554
18 Dec 2013 10:37 #615819
by zed1015
Replied by zed1015 on topic trouble reinstalling crank in kz1000
You could mark the bearing outers with marker pen opposite the holes (180 degs) so you know the holes are somewhere in the right area when the marks are lined up facing you , then while supporting one end of the crank with your hand start with the furthest away and work your way along.
You will be able to feel each pin locate and the crank will drop slightly as each pin locates.
Don't let the crank rock on a pin as it will lift off the one's you've done and you'll be back to square one.
Should only take a minute to seat the crank with this method.
I don't actually mark the bearings myself as I just feel them in as mentioned but it should make it a bit easier for you.
- baldy110
- Thank you received: 512
18 Dec 2013 13:24 - 18 Dec 2013 13:26 #615839
by baldy110
Replied by baldy110 on topic trouble reinstalling crank in kz1000
I stored my Gpz1100 crankshaft for about 4 years in a box wrapped up with oiled rags. When I went to put the crank back on it was bent, I ended up getting another crank. The crank was true when I stored it. I did not however have your problem all the bearings went back into their respective studs with ease. On mine when I torqued the middle main bearing cap the crank would have a really tight spot when rotated.
Last edit: 18 Dec 2013 13:26 by baldy110.
- kamakazie1000
18 Dec 2013 15:12 #615848
by kamakazie1000
kz1000 cafe project
Replied by kamakazie1000 on topic trouble reinstalling crank in kz1000
i managed to get it. just stepped away for a minute, drank a beer, came back and got it on the first try. thanks for input though!
kz1000 cafe project
- Bozo
- Ride it like u stole it
- Thank you received: 105
18 Dec 2013 16:07 #615853
by Bozo
Replied by Bozo on topic trouble reinstalling crank in kz1000
Maybe, in the future all manuals should include " if it doesn't work Stop, have a beer and work on it later' . How many times has this statement been made??.
For the politically correct we should include a brand name and a statement "do not ride after repairs, get a skipper to take it for a test ride" :laugh:
