1980 kz 550 loosing power
  • michalw
  • michalw's Avatar Topic Author
09 Dec 2013 14:16 - 09 Dec 2013 15:08
#615130
hi, I have brought a 1980 kz 550 that has sat for around 20 years and I got it running but the problems that I am having are after I let it warm up I go take it for a 5 min ride and it starts to loose power, it revs very slowly under load but when I stop and rev it it revs just fine. That only happens when the bike is all warmed up, when its cold it has all the power. also when I rev the engine real fast at low idle the bike just dies, also most of the time the bike does not want to return to a even idle after revving it. what would cause these problems?
I have rebuilt the carbs with stock jet sizes,
new (used ignition coils) with new plugs, plug boots and new wires ( made big power difference)
bike is all stock except for a dyna s electronic ignition that the last owner installed
Compression test is around 150psi on all cylinders, no smoke, no strange knocking
Last edit: 09 Dec 2013 15:08 by michalw.
  • steell
  • steell's Avatar
Re: 1980 kz 550 loosing power
09 Dec 2013 20:23
#615153
Probably a vacuum leak at one (at least) of the carb holders (rubber boot between carb and cyl head).
Spray some ether ( or wait for later suggestions if not sure) at the boots where they meet the head while the motor is running. If the motor speeds up, then you found the leak.
09 Dec 2013 21:06
#615162
Would also check valve clearances to determine whether they are in specs.
Good Fortune! :)
  • michalw
12 Dec 2013 13:38
#615388
i did not find a vacuum leak, the bike idles fine on all 4 cylinders its just when its warm it looses power it feels like its only running on 3, when it cools down the power is back, the coils aren't hot, could this possibly be caused by float bowls being un even? i checked them today and did not find much of a difference between them, when i had the carbs upside down i could see one float a little higher than the others. would this problem be fuel or spark related.
  • michalw
12 Dec 2013 13:52
#615389
the bike also has a little over 13000 miles and i dont hear any valves ticking, would my symptoms possibly be tight valves?
12 Dec 2013 13:57 - 12 Dec 2013 13:57
#615391
michalw wrote: i did not find a vacuum leak, the bike idles fine on all 4 cylinders its just when its warm it looses power it feels like its only running on 3, when it cools down the power is back, the coils aren't hot, could this possibly be caused by float bowls being un even? i checked them today and did not find much of a difference between them, when i had the carbs upside down i could see one float a little higher than the others. would this problem be fuel or spark related.
You cannot accurately measure carb bowl fuels levels by looking at the floats. The only way to tell what the fuel levels truly are is the "clear tube" method. See link below:
kzrider.com/forum/2-engine/580335-homead...at-level-tool#580344
Last edit: 12 Dec 2013 13:57 by 650ed.
12 Dec 2013 20:25 - 12 Dec 2013 20:26
#615420
Yes.
Absence of audible ticking is inconclusive, and would actually be consistent with too tight valves.
Acceptable cold performance deteriorating when warmed is classic symptom of a too tight valve.
Perhaps valve clearances have never been checked.
Would suspect 13,000 miles is likely well beyond factory instructed routine maintenance.
Clearance is quick and easy to check.
Simply place thickness gauge between cam and bucket with cam lobe pointed away from the bucket.
Clearances might be within spec,
Good Fortune! :)
Last edit: 12 Dec 2013 20:26 by Patton.
