valve clearance
  • dady619
  • dady619's Avatar Topic Author
Re: valve clearance
08 Oct 2013 19:05
#609292
015mm way to much
Re: valve clearance
08 Oct 2013 20:00 - 08 Oct 2013 20:02
#609296
Even with minimal clearance, a valve should completely seal when the engine is cold (such as during a load test).
If there's minimal clearance, valve leakage when cold is likely due to an issue other than clearance being less than spec.
Good Fortune! :)
Last edit: 08 Oct 2013 20:02 by Patton.
  • dady619
Re: valve clearance
09 Oct 2013 02:47
#609332
my valve is not closing I pulled my old spare motor town and almost every valve is leaking from carbon build up
