Need help with setting valve clearence ....please.
  • anotherZ
  • anotherZ's Avatar Topic Author
04 Oct 2013 10:30
#608759
So my bike (1979 KZ 1000 LTD, with an MKII engine) was running well but just to be on the safe side I took the valve cover off to check the valve clearances. Most of my exhaust valves are at 0.05mm (one is slightly below, but can't measure for sure), the intake valves are in the 0.1-0.15mm range. Here my questions:
Is this an acceptable range or do I need to do anything about it?
If I need to change shims, do I need to remove the cam and do I need a special tool to hold down the valves?
Bonus question :) How can I tell whether the cam is aftermarket or original?
Thanks a lot for any input!
Olaf
79 KZ 1000 LTD
Saved it from becoming a drag bike
Smaller tank
  • anotherZ
Re: Need help with setting valve clearence ....please.
06 Oct 2013 17:55
#608970
Bump...
If someone can help, please let me know, at least about the clearences (0.05-0.15mm?)
Thanks.
79 KZ 1000 LTD
Smaller tank
  • Motor Head
  • Motor Head's Avatar
06 Oct 2013 18:06
#608974
Sounds like the EX valve is to tight, and its good you are checking. Better to run the EX a bit looser, .10mm = .004"
  • RonKZ650
  • RonKZ650's Avatar
06 Oct 2013 18:10
#608977
.05mm is pretty much the minimum that can be run, so that one valve should be adjusted by one or two sizes down to get back to .10-.15mm. The job is easy if you have the holder tool to hold the valve open, see what shim is in there and determine what you need. No need to remove cams on the KZ1000, but you need the holder tool. Used to be a factory Kawasaki tool, now I think Motion Pro sells it, but not sure about that
  • 80B4
  • 80B4's Avatar
06 Oct 2013 18:18
#608980
Yes, the exhaust valves are too tight. Try to keep them at .15mm. Z1 Ent. has the hold down tool for less then $10. No need to remove the cams to change shims. Some aftermarket cams have lnfo stamped on the ends. Measure the hight of lobe and compair it to the stock numbers.
1980B4 1000
1978 Z1R
1978 B3 750
  • anotherZ
06 Oct 2013 18:41
#608986
Great, thanks! Will get the shim tool, shims and get going. Too bad I need to place two orders, one for the tool, then after I know which shims I need another one for the shims...
79 KZ 1000 LTD
Smaller tank
  • bluezbike
  • bluezbike's Avatar
06 Oct 2013 20:01
#608998
When you get the shim tool make sure you write down somewhere what shims you finally end up with as well as the gap you set so next time will be a lot easier. Also by doing some juggling you may need to buy fewer shims. One thing I would suggest also is to get a metric feeler gauge set (NAPA sells them for about $12) You will use them a lot. ;)
79 KZ 1000 LTD
  • anotherZ
06 Oct 2013 21:37
#609002
Makes sense. And I have the metric feelers already, definitely makes things easier.
Again, thanks.
79 KZ 1000 LTD
Smaller tank
