Endless Oil Leaks
  • SkidZmark
  • SkidZmark's Avatar Topic Author
Endless Oil Leaks
23 Sep 2013 19:16
#607470
Hi folks..
I have a 1975 Z1 900 with a 1390cc motor, built with mostly APE parts. Using a 1982 KZ1000 J head.
It's a nice bike to ride, but I am forever chasing oil leaks. Piping an extra breather out of the oil filler cap helped, but I can't seem to stop the cylinder base from leaking. I'm using an 80 thou aluminum base spacer to get the deck height I need, with stock paper gaskets on either side. Used a bit of ThreeBond 1211 silicone. Seemed like it was OK until I did a re-and-re on the head. Now it's leaking significantly.
Weird. The first advice I received (from APE) was to install the aluminum base spacer without paper gaskets, just using some copper sealant. That leaked, so now I've tried paper gaskets on either side.
It doesn't leak much if I idle around, but throttle up even a little and it gets messy. Don't think I'm building unusual crankcase pressure- my catch bottle isn't collecting much.
Why does this area want to leak so bad?! Very frustrating, I must say.
Any thoughts would be appreciated - -
Mark
"SkidZmark"
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
Re: Endless Oil Leaks
23 Sep 2013 20:59 - 23 Sep 2013 21:26
#607491
You could try a top end oiler kit.
You could try remote oil line to the head and bypass the stock oil passage though the case and up the outer stud passage / cylinder to head.
Just get the pressurized oil out of that area.
Last edit: 23 Sep 2013 21:26 by 4TheKZ1000.
  • baldy110
  • baldy110's Avatar
23 Sep 2013 22:39
#607502
Anytime you pull the head off these you will most likely upset the base gasket and then when you put the head back on it will leak. You need to be VERY CAREFULL when removing the head or just replace the base gasket every time you take the head off.
  • SkidZmark
24 Sep 2013 00:18
#607513
Thanks for the input.
Have to admit I hate replacing base gaskets. Mostly because I have so much trouble sliding the barrels back on to the pistons. Snapped enough rings I have a guy at the shop do it now.
Even with the pistons already in the bores, then tapping them down to align with wrist pin holes. Can't seem to do it- they always spring free before I can get them hooked up. The guy at the nearby shop is able to do it, but I think he's sick of seeing me.
Mark
  • MDawnz1
  • MDawnz1's Avatar
24 Sep 2013 02:16
#607531
SkidZmark wrote: Hi folks..
Mark,
Here I go again,
There is NO place on any bike engine where you can use silicone,EVER, unless it's an emergency.
So it sounds like your silicone failed,
OR
If you are building that much pressure in your cases it sounds like a broken ring or two.
PS If you remove the 2 paper gaskets and just use spray copper coat on the spacer you do know you are raising your deck height (and compression) by the thickness of 2 compressed paper gaskets right?
Good luck
Mike
1974 Z1a, still 903
The following user(s) said Thank You: SkidZmark
  • Lt.Dan
  • Lt.Dan's Avatar
24 Sep 2013 23:10
#607671
What is your engine breather system. You might be running way too much pressure from those big pistons stirring up all that air in the cases.
  • SkidZmark
25 Sep 2013 21:56
#607792
Re: crankcase breathing. I use the stock bell housing breather, on the flat part of the block beneath the carbs. I tried a cool looking APE low-rise breather cover, but got oil spray. Seems the baffles inside the bell housing are necessary.
At any rate, the motor continued to push oil out every crack it had until I added an extra breather from the oil filler cap- I run a tube from a hole in the filler cap to a catch bottle. The leaks settled a bit, but I wonder if I've adequately dealt with the crankcase pressure issue. If I haven't, I'm not sure what else there is to do. Any ideas..?
Re: use of silicone. I thought it would provide the best base gasket seal. I'm hearing enough negative reviews on use of silicone to simply stop using it. Next assembly I'll use copper spray. Just hope it has the same sealing ability. Also, when adding paper gaskets to the base assembly, I used a narrower aluminum spacer, to duplicate proper deck height.
The bike runs well. If it would stop leaking I'd be a happy guy.
Really appreciating the advice and input..
Mark Tonner
  • Motor Head
  • Motor Head's Avatar
25 Sep 2013 22:06
#607793
Have you done a Leak Down Test, to see if the rings are indeed sealing properly?
  • Lt.Dan
  • Lt.Dan's Avatar
26 Sep 2013 04:11
#607830
SkidZmark wrote: Re: crankcase breathing. I use the stock bell housing breather, on the flat part of the block beneath the carbs. I tried a cool looking APE low-rise breather cover, but got oil spray. Seems the baffles inside the bell housing are necessary.
Mark Tonner
I think you need to vent the valve cover, did you remove the two rubber pipes inside the derby breather and leave the plate? Years ago a friend built a big motor and used the exhaust system flow to help vent the crankcase. You need to try and look up some old Kawa drag bikes to see how it was done way back when. That engine only has 4-6 lbs of oil pressure because of the roller crankshaft....
  • Puffin
  • Puffin's Avatar
26 Sep 2013 10:44
#607849
Skidz as Motorhead says it might be blowing by the piston rings, a friend has had this on his GSX. Which made for alot of head scrathing until we figuered it out :S Try a compression test. If thats not the answer APE`s Jay is a member here and should be able to point you in wright direction
KZ1000 J Long Term Owner
KZ1100
KZ1100 Spectre project
  • Powerstroke_fan
  • Powerstroke_fan's Avatar
27 Sep 2013 08:36
#607968
First off your going to have oil leaks running that big motor, unless you dry block (external oil feed line) it. someone posted a link on how to sleeve the oil galleys to stop the oil leak. Mine leaks oil also. I turned both of my cam cover emmission ports into crankcase vents, by just removing stoc reed valves drlling two holes in the inside and filled it with steel wool to work as a bafffle works great so far. You will have allot higher crankcase pressures running them big pistons. But you could still do a compression test if you thought there is a problem.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
  • Cynjut
  • Cynjut's Avatar
27 Sep 2013 13:48
#608004
I'm sure everyone already thought of this, but are you running 4 quarts or 3.5 quarts of oil?
It's a stupid question, but it might be that the additional crankcase pressure combined with too much oil is making these leans an inevitability. The fact that you're blowing out of the breather is the only reason I'm asking - that's the first symptom of too much oil.
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
