Frozen engine
  • Donahue
  • Donahue's Avatar Topic Author
Frozen engine
14 Sep 2013 21:32
#606452
My 1976 KZ750 B1 was in a flood. I drained the water out and put some oil in and it turned over just fine with the kick start. Then we went on vacation for a few weeks and when I returned it was frozen ( won't turn over ) I tried several things oil in cylinder, Fuel oil Mystery oil a little heat ( don't want to warp the heads).
Should I take out the motor put it on a bench and tear it down.
I am a vet with some health problems and would like to get this back on the road. Any help would be appreciated.
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
Re: Frozen engine
14 Sep 2013 21:53 - 14 Sep 2013 21:55
#606454
First of all...thanks for your service.....sorry for your trouble. Floods suck and we can feel your pain. Hope you get it behind you fast and get back to normal.
If its was mine and I could justify the teardown and rebuild costs....and bike was worth it, I would rebuild.
Sounds like you have a rusted up engine. It needs to be gone though, cleaned and some new parts and gaskets should get you up and rolling.
Good luck.
Last edit: 14 Sep 2013 21:55 by 4TheKZ1000.
  • bountyhunter
  • bountyhunter's Avatar
Re: Frozen engine
15 Sep 2013 02:12
#606480
The piston rings may have rusted to the cylinder walls.
The following user(s) said Thank You: Donahue
  • Puffin
  • Puffin's Avatar
Re: Frozen engine
15 Sep 2013 05:41
#606491
Donahue, how long was it stood ? i ask because if not stood long then you may be able to free it up with diesel or a rust penetrant. Rust takes awhile before it can pit the bore
KZ1000 J Long Term Owner
KZ1100
KZ1100 Spectre project
  • Donahue
Re: Frozen engine
16 Sep 2013 15:03
#606684
It stood about a year after i Put oil in it At the time I drained out the water and oil and put new oil in it and with the kick start it turned over fine. I am having electrical problems as well.The bike was full of river silt. most of that is gone. the rusting occurred when we went on vacation for two weeks last spring.
  • 4TheKZ1000
Re: Frozen engine
16 Sep 2013 15:13 - 16 Sep 2013 15:14
#606687
IT SAT FOR A YEAR ????......it will make a nice boat anchor...... :dry:
Last edit: 16 Sep 2013 15:14 by 4TheKZ1000.
Re: Frozen engine
16 Sep 2013 17:14
#606696
Donahue wrote: It stood about a year after I Put oil in it. At the time I drained out the water and oil and put new oil in it and with the kick start it turned over fine. I am having electrical problems as well.The bike was full of river silt. Most of that is gone. the rusting occurred when we went on vacation for two weeks last spring.
What makes you think it stopped rusting when you returned from vacation? :unsure: Ed
  • sbc1320
  • sbc1320's Avatar
Re: Frozen engine
16 Sep 2013 17:54 - 16 Sep 2013 17:55
#606698
Sounds like teardown time. If it is rusty in the cylinder and you get it freed up the rings will act like scrapers and then they will become stuck with the rust and crud.
Better to tear it down and hone it and rering it. Good luck with it.
What was the name of that song? Oh yeah "Rust never sleeps"
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
Last edit: 16 Sep 2013 17:55 by sbc1320.
  • MDawnz1
  • MDawnz1's Avatar
Re: Frozen engine
16 Sep 2013 19:13
#606707
Hay Man,
Thanks from me too,
Now onto the bike,
They are right, rust never sleeps,
So spray whatever you can get your hands on into the plug holes NOW !!
WD 40, PB Blaster ,CRC 5-56 anything.
It will help when you have to pull the cyl. off.
Fighting with 4 frozen pistons all at the same time is NO fun.
Good luck with it.
Mike
PS Fill out your profile, maybe someone is close enough to help
1974 Z1a, still 903
  • CrazyDuck
  • CrazyDuck's Avatar
Re: Frozen engine
17 Sep 2013 13:38
#606791
I hate rusted cylinders! Usually letting the cylinder soak in oil and rocking the bike back and forth with it in gear will free up the stuck cylinder(s). This at least makes disassembly easier.
I don't want any excuses about not being able to get a piston out unless it looks like this! :pinch:
Attachment IMG_1029.JPG not found
1976 KZ900
1974 TX500
1978 TT500
2007 Aprilia SXV
  • Donahue
Re: Frozen engine
17 Sep 2013 18:23
#606830
:woohoo: Duh!!! I don,t know
  • toolmaker
  • toolmaker's Avatar
Re: Frozen engine
18 Sep 2013 10:23
#606909
Donahue wrote: :woohoo: Duh!!! I don,t know
Don't feel bad about that.....most old barn finds are bikes that just got put away after summer and never rode again.
I live near Portland, Oregon and my rider is a '76 KZ900 I bought new. I'm also in the process of restoring another one and a '73 Z1.
