Frozen engine
- Donahue
Re: Frozen engine
24 Sep 2013 23:13
I took off the heads lightly tapped the pistons with a rubber mallet and it came free :laugh:
Now I need to put it back together. Any dea ho w to get the timing right. I know appoximately where the pistons were.
So should I try that and put the cams back in and see what happens or is there a trick to it :silly:
Re: Frozen engine
24 Sep 2013 23:17 - 24 Sep 2013 23:27
Yes, there's a trick to it. It's known as using the Kawasaki Service Manual (see link below for PDF)
That's the only way to know for sure how to put the engine back together without damaging anything. Ed
www.theotherstyle.info/manuals/bikes&atv...i%20KZ750%20Twin.pdf
Last edit: 24 Sep 2013 23:27 by 650ed.
- Donahue
Re: Frozen engine
25 Sep 2013 11:43
The gaskets look good on this bike. Should I use them or replace them. If replace where can I get gaskets sets for the 1976 750 B1.
Also, the side covers washed away in the flood where can I get some more.
- baldy110
Re: Frozen engine
25 Sep 2013 12:34
Replace the gaskets. Also if this happens again, hopefully it won't, change the oil and filter and ride the bike for a while, getting it good and warmed up. That way the heat from the engine will evaporate whatever water is present then change the oil and filter again and you should be good.
- Donahue
- Cynjut
Re: Frozen engine
25 Sep 2013 16:38
Z1 Enterprises is a good place to start. The dealership is the bad place to end.
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
- Donahue
Re: Frozen engine
09 Oct 2013 16:09
whats the trick to getting the headgasket in on a 750 twin.
- Donahue
Re: Frozen engine
09 Oct 2013 16:11
WE HAD OTHER THINGS TO WORRY ABOUT LIKE FIXING THE HOUSE ETC. LOL
- Cynjut
Re: Frozen engine
09 Oct 2013 17:57
House? Hmmph. You don't need a house - that's why God invented tents. Some people's priorities are just all wrong.
1977 KZ-1000 A1
