1000 crankshaft questions
- peavylotus
- Movin on up
12 Sep 2013 05:45
How do you check the inner bearings on a crank and is there a side to side movement tolerance on the rods and crank?
I am debating sending my crank to Falicon to have it rebuilt but I want to see if there are ways to see if its good.
1980 KZ 1045 LTD Currently Workin' It Out
- Powerstroke_fan
Re: 1000 crankshaft questions
12 Sep 2013 07:31
I believe you got to compelety disassemble the crank to inspect the bearings.
1977 KZ 1000 work in progress
12 Sep 2013 10:36
without dis-assembling it.
you check for "up and down"by rotating the rod to the top and feeling for "up and down" clearance.
you can check side play with feeler gauges.
there should be specs for what the rod side clearance should be in your manual.
hth,
hth,
- DFIGPZ
13 Sep 2013 22:26PM SENT.peavylotus wrote: How do you check the inner bearings on a crank and is there a side to side movement tolerance on the rods and crank?
1984 750 Turbo
