Engine Cases
  • geerbangr
  • geerbangr's Avatar
Re: Engine Cases
10 Sep 2013 23:03
#605927
Unless I'm not seeing the whole picture I'd split the case, weld the boogered hole up and have it remachined. If you chose to have it repaired show us the after pics.
1978 KZ 1000
I go by Jason
  • bluezbike
  • bluezbike's Avatar
Re: Engine Cases
11 Sep 2013 00:06
#605951
Cases (top and bottom halves and camshaft cap) are line bored as a unit and are not interchangable....there could be a match using different halves on the stray chance but it isn't something you can plan for. I think calling Pit Stop first to talk with them is a good first step as I think plug welding the hole could work. If your bike is a matching numbers one then it might be the best option to keep the cases. Good luck :)
79 KZ 1000 LTD
  • MDawnz1
  • MDawnz1's Avatar
Re: Engine Cases
11 Sep 2013 02:46
#605971
Do you still have the piece the broke out?
If so ,,,,,,,,,,,,,It's a piece of cake for "THE RIGHT WELDER"
Done right it wont even need any kind of insert.
I have seen it done MANY times.
When you find "THE RIGHT WELDER"
All you need to do is pull the tank,drain the fuel before and change the oil and filter after.
Just make sure you check out other work they have done BEFORE you turn them loose on your bike.
1974 Z1a, still 903
  • Vranasaurus
  • Vranasaurus's Avatar Topic Author
Re: Engine Cases
11 Sep 2013 17:02
#606045
I talked to Joe at pit stop performance and I am going to send them the lower half of the case for repair.
Pulling the engine and splitting the case. Oh joy!
1984 ZN1100
1975 Z1B
  • floivanus
  • floivanus's Avatar
Re: Engine Cases
11 Sep 2013 20:21
#606071
Inspect your trans while you're at it, and see if you have to get it back cut while youre in there
Past; 78 kz1000, 83 kz550
Andrew
  • 74ullc
  • 74ullc's Avatar
Re: Engine Cases
11 Sep 2013 22:15
#606085
Did the hole used to project out of the case even with the bolt hole next to it?
What happened? It looks like you put a black cat in the hole and lit it off. All the little chunks laying there.
Gulf Coast, Texas
1977 KZ1000LTD
1984 VF700F
  • geerbangr
Re: Engine Cases
01 Oct 2013 00:50
#608429
Vranasaurus how did the repair go ?
1978 KZ 1000
I go by Jason
