engine leaks
- chiaronate
06 Sep 2013 14:31 #605210
by chiaronate
1982 Kawasaki KZ1100 Spectre
engine leaks was created by chiaronate
I recently bought a kz1100 with an oil leak, thinking I could just have the leak fixed. A few mechanics told me that because of the design of the motor, any fix would be temporary because it would soon leak again. Is there a permanent fix for this?
- geerbangr
- Thank you received: 4
06 Sep 2013 14:44 #605213
by geerbangr
1978 KZ 1000
I go by Jason
Replied by geerbangr on topic engine leaks
Where exactly is the leak coming from ? I built an 1100 several years ago and never had leak issues. Unless it has been extremely modified I wouldn't think the leak would be reoccurring after resealing. Feed us some more info.
1978 KZ 1000
I go by Jason
- chiaronate
06 Sep 2013 14:49 #605216
by chiaronate
Replied by chiaronate on topic engine leaks
Thanks for replying so soon, a mechanic I talked to seems to think it's from the cam chain. His explanation was the valve cover gasket doesn't have a hole there. Another mechanic at a different shop said he used to have a similar bike, and it leaked within a year of fixing it. He said that's just the way these motors are.
- Thank you received: 2829
06 Sep 2013 14:54 #605219
by 650ed
Replied by 650ed on topic engine leaks
These bike are very oil tight, so it shouldn't leak. Here's my recommendation - clean the entire area everywhere near the leak squeaky clean. Then ride the bike a few miles and check to see if it's leaking. Take you camera with you and take some pictures of the leak so we can see the source. Post he pictures and someone here will very likely be able to tell you the probable cause. Ed
- chiaronate
06 Sep 2013 14:57 #605223
by chiaronate
OK thanks Ed, I'll get some degreaser and clean it..I've been meaning to do that anyhow.
- 4TheKZ1000
- Visitor
06 Sep 2013 15:21 #605227
by 4TheKZ1000
Replied by 4TheKZ1000 on topic engine leaks
get some good pictures posted of the problem areas.
- chiaronate
06 Sep 2013 15:32 #605228
by chiaronate
I just finished de-greasing, but it may be hard to see where the leaks are coming from by the pictures. The guy I bought the bike from painted the gold engine areas black. I really wish people wouldn't cob things like that, I like things to be original. I'll go for a ride now and take pictures after.
- chiaronate
06 Sep 2013 16:49 #605241
by chiaronate
OK I went for a 15 or 20 minute ride, the only liquid I could see is at the center of each side of the motor. Does that make any sense?
Attachment IMG-20130906-00002.jpg not found
Attachment IMG-20130906-00003.jpg not found
- chiaronate
06 Sep 2013 16:53 #605243
by chiaronate
I also took some more pictures while I was doing that, because we all like pictures.
- gwolever
- Thank you received: 8
06 Sep 2013 20:03 #605265
by gwolever
1982 KZ1000 CSR
Replied by gwolever on topic engine leaks
Not sure exactly where the leak is but in pictures it sorta looks like it's from head gasket. Not sure though from the pics.
1982 KZ1000 CSR
- chiaronate
06 Sep 2013 20:07 #605266
by chiaronate
That's what I was thinking, is that a big deal to have done?
- koolaid_kid
- Thank you received: 99
06 Sep 2013 21:01 #605273
by koolaid_kid
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
Replied by koolaid_kid on topic engine leaks
First, the easiest way to pinpoint an oil leak is to clean the area throroughly and then dust the area with talcum powder (baby powder, foot powder).
Second, paying someone to replace the head gasket is easy but expensive for you.
Replacing it yourself is more difficult and about one fifth the price.
1983 GPz 750
